Warning NVIDIA 196.75 Drivers kill cards Just a heads up in case anyone installed these. Quote:
Water cooling > * |
Well at least for Windows 7 you can't install/run these drivers, i looked in both the beta and latest and its no where to be found |
Best drivers I've used in awhile but I always set fan speed manually . |
There is a workaround in the registry similar to the wrong GPU error of a previous driver version. Official NVIDIA Forceware 196.75 display driver feedback thread - NVIDIA Forums I didn't have temp problems when I had the 196.75 driver even when I had MSI Afterburner set the fan control to Auto. I rolled back to 196.21 though as the 196.75 doesn't have 3D vision drivers yet. |
Overheating WILL NOT kill a modern GPU. For the last half decade (possibly more) every GPU has a built-in thermal sensor and accompanying thermal shutdown routine. Once the GPU hits a certain temp, a shutdown is initiated. That's it. It should be noted however that high heat over prolonged periods of time will shorten the life of components. Maybe the drivers are messing with fan control but like I said, overheating won't kill a GPU. This seems like a perfect example of a developer's tech support talking about something they know nothing about. |
(I <3 Linus) |
Shows you how pointless the WHQL certificate is... |
| All times are GMT -7. The time now is 07:09 PM. |
