Old February 26, 2010, 10:25 AM
Default Help finding drivers please
MAXNOTE 9055-128 GRAPHIC P4 NOTEBOOK
Specific details are below. Any help would be appreciated. I need drivers for chipset, LAN and cpu. (I think.) It's running fine now, I would like to get it on the web though. Thanks!
Specifications
Model
CPU
IntelŪ PentiumŪ 4 Processor up to 3.06 GHz (support HT)
Socket 478 400/533Mhz FSB 512KB L2 Cache
Chipset
North Bridge: Intel 845PE
South Bridge: Intel ICH4
Display
15 SXGA+ TFT LCD Display 1400X1050 Pixels
Operating System
Microsoft Windows XP / Microsoft Windows 2000
Memory
Available Socket: 2
DIMM Type: 184 Pin non-ECC DDR SDRAM (DDR 333/266) desktop memory
Maximum Supported RAM: 2048MB
Hard Disk
2.5 EIDE HDD (4200/5400/7200RPM)
Optical Drive
CD-RW (Optional); DVD/CDRW Combo; DVD-RW (Optional)
Graphics
nVidia GeForce FX GO 5600 128M VRAM
3D Graphics Engine
AGP 2.0 Compliant
Sound
AC97 V2.2 Compliant Audio
Sound Blaster Pro Compatible
Old February 26, 2010, 10:37 AM
Specifications
Model
CPU
Chipset
Display
Operating System
Memory
Available Socket: 2
Hard Disk
Optical Drive
Graphics
3D Graphics Engine
AGP 2.0 Compliant
Sound
Grab this gem:
SIW | System Information for Windows by Gabriel Topala
And see what your network adapter uses in that laptop.
Old February 26, 2010, 11:01 AM
Nifty tool. Will report back. Thanks
Old February 26, 2010, 05:30 PM
JD JD is online now
And once you get the NIC working, the rest could probably be had off Windows Update.
Old February 27, 2010, 04:48 PM
Default rs
What am I looking for to identify what drivers my NIC card uses? I'm reformatting now and will run it shortly. This is my first opportunity to mess with it since my post.
Thanks for your help
Old February 27, 2010, 07:05 PM
JD JD is online now
Find out the make and model, then just search it on Google. Should find a driver pretty quickly.
Old March 1, 2010, 06:34 AM
Thanks. Got it.
That's a great little tool.
Tags
drivers , maxnote p4 notebook
nvidia drivers with ati drivers. kyle_L O/S's, Drivers & General Software 0 January 8, 2010 11:05 PM
Help finding a component: Rommel Audio 3 February 3, 2009 09:48 AM
i need help finding a program EaGle1337 Off Topic 0 January 26, 2009 06:37 PM
Need help finding a certain cable Kentalish Audio 5 July 10, 2008 07:52 AM
Need some help finding those ebdoradz Off Topic 0 March 17, 2008 08:42 AM
