-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Catalyst 10 + CS4 = no work? (OpenGL related?) (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/29173-catalyst-10-cs4-no-work-opengl-related.html)
oblisk February 23, 2010 03:33 AM
Ever since I went to 10.2s from 9.8, my CS4 Photoshop wouldn't start. I looked around the web and found something that may be related with the new 10 drivers.
When I start photoshop, I get this error message "LoadLibrary failed with error 126: The specified module could not be found." and it exits.
Anyone with an ATI card + CS4 Photoshop try this?
Same problem as here: Solved LoadLibrary failed with error 126 - Windows 7 Forums
But I don't want to rollback drivers...
edit: Uninstalling the drivers fixed it, I can run Photoshop. But once I reinstalled the 10.2s, same problem.
SKYMTL February 23, 2010 06:58 AM
CS4 makes use of GPU acceleration. It sounds like ATI broke yet another item in their drivers which is why the program won't start.
I am not sure about which checks CS4 performs when it starts but here is what I would recommend you do:
- Load 9.8 drivers
- Go into CS4, Edit > Preferences > Performance and turn off the "Enable OpenGL Drawing" option
- Load 10.2 drivers and hope that CS4 doesn't do any GPU checks if you have turned off GPU acceleration
See if that helps.
TopDogZero February 23, 2010 01:08 PM
No problems here with CS4 and 10.2, GPU acceleration is working as it should.
martin_metal_88 February 23, 2010 01:15 PM
Same on few costumer PC we get out last week and yesterday. It's a wierd issue you have sorry my friend.
oblisk February 23, 2010 04:58 PM
Nothing :(
I'm gonna give the 10.3 betas a go...
oblisk March 19, 2010 02:07 AM
Update:
10.3 leaked didn't help, neither did the 10.3a Previews that was just released. I can't run *any* OGL programs. I've tried driver cleaners, uninstall/reinstall 10.3s, etc.
Is it possible to somehow reinstall OGL drivers seperately?
