-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Driver removal? (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/28954-driver-removal.html)
encorp February 16, 2010 01:31 PM
Driver removal?
Which tools do you use to remove and clean your system of drivers before installing new ones?
I used to use driver cleaner, but every where I look apparently it's no longer updated??
gingerbee February 16, 2010 02:29 PM
driver sweeper is what i use
Guru3D - Driver Sweeper
Zero82z February 16, 2010 03:28 PM
Nothing. I just install the new drivers over the old one, which you can actually do in Vista and Windows 7 without screwing something up.
