Old February 8, 2010, 12:02 PM
r0k0's Avatar
Default Worth the Upgrade..?
Hey, I've got on my main Hard drive Vista Ultimate x86, and i've installed on a Spare HDD W7 Ultimate x64 and i've installed games but they dont appear in the menu or desktop.. i have to go directly into the x86 program files folder..
this is annoying... should i just get W7 Ultimate x86 and miss out on the extra 700mb of ram ?
but i gotta say that W7 is very fast compared to Vista..!
i know the windows experience index aint a benchmark.. but from Vista i had max 6.9 on cpu and the score was 5.9 because of my har drive... its still is but all the other are at 7.2-7.3 in W7 x64 lol
Main Rig
Intel Core i5 2500K
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
Sapphire Radeon HD 5970 2GB
Thermaltake Spedo / Coolermaster Silent Pro 1K
A-DATA 120GB SATA3 SSD / WD 500 GB Blue SATA2
Canadian Eh ?
Old February 8, 2010, 12:27 PM
gingerbee's Avatar
create short cuts and put them on your toolbar or desktop. problem solved no upgrade need
Old February 8, 2010, 01:06 PM
wait, what?
I dont get your problem.
where are these games installed? on what operating system? what is your primary operating system? do you even have two operating systems for a reason?
Old February 8, 2010, 04:54 PM
r0k0's Avatar
i only have 1 OS.. Windows 7 Ultimate x64 and in the C: drive theirs " Programs Files" and "Programs Files ( x86 )"
Main Rig
Intel Core i5 2500K
Canadian Eh ?
Old February 8, 2010, 05:07 PM
MarkOne's Avatar
it's normal with X64 os the software that does not run in 64 bits go in the x86 directory.
Old February 8, 2010, 05:08 PM
r0k0's Avatar
ok cool.. can you explain 1 thing tho.. on my nefew's computer i just built.. i installed Mass Effect and Made Man.. both wont run...
Main Rig
Intel Core i5 2500K
Canadian Eh ?
Old February 8, 2010, 05:13 PM
MarkOne's Avatar
start with downloading the direct x from Microsoft. especially if you use Vista 64 bits or Win7 64 bits use the admin Install at the bottom of the page . I pass a lot of time to figure the Webinstall do not work with my windows 7
this is the admin install, download, right click and choose run as admin
Download details: DirectX Redist (August 2009)
Old February 8, 2010, 10:31 PM
r0k0's Avatar
updated the game and works now.. lol
Main Rig
Intel Core i5 2500K
Canadian Eh ?
Old February 9, 2010, 08:03 PM
r0k0's Avatar
Steam on my main computer will not work for some reason.. it worked when i installed, tryed playing a game.. didnt boot.. then after that i restarted the pc.. now it say connecting to r0k0 then the image appears in the bottom of the screen. when i click it, it doesnt pop up.. or i cannot load any games...
says i need to be connected to steam in order to play
Main Rig
Intel Core i5 2500K
Canadian Eh ?
Could someone tell me what this is worth? BootlegUsher Off Topic 14 December 19, 2009 02:14 PM
Still worth it? BrokenHalo83 Off Topic 0 April 18, 2009 03:40 PM
what do you think she's worth? Mr. Friendly Mobile Computing 6 January 3, 2009 09:38 PM
core 2 to i7 is it worth the upgrade? magictorch CPU's and Motherboards 25 December 3, 2008 09:28 PM
Opteron 165 to an e5200 worth the upgrade? vulcan500rider CPU's and Motherboards 17 November 1, 2008 11:54 AM
