Old February 9, 2010, 04:33 PM
Thanks AKG
I'll stick with what I've got. Now if I only hadn't installed the 10.1 ATI video driver. Aren't computers fun!
ASUS P7P55D-E Pro - Intel i7 860 - Zalman CNPS 10X Quiet - 4gb G.Skill Ripjaws DDR3 1333 CL7-7-7-21 1.5V - Intel 520 Series 240 GB SSD - WD Caviar Black 1Tb - Corsair TX750W - Sapphire Radeon HD 5770 1 Gb GDDR5 - DVD Drives X2 LG GH24LS50 - Coolermaster CM690 II Advanced - Win 7 Pro 64
Old April 13, 2010, 07:19 AM
Default New (to me) info on Intel SSD
Originally Posted by AkG View Post
IIRC, Intel Matrix drivers DONT support trim. This means that even though you are in AHCI mode ( I assume since you are not running a RAID) your SSD will degrade. I would either setup the manual trim option in the Intel toolbox....or swap over to MS AHCI drivers and get TRIM!
Hello everyone
I don't completely understand all of this and am struggling with the new info. I recently got some info regarding my Intel X25-M 80gb. SSD. I've been using the Windows AHCI driver because It was suggested by some on this site and others that it was better. The Intel driver apparently didn't pass the trim command to the OS. I now have some new info (new to me anyway) that says Intel's new driver corrects all of this? Could someone please give me an opinion on which driver I should use.
See links
http://www.intel.com//support/chipse.../CS-022304.htm
Intel RAID driver adds pass-through TRIM support - The Tech Report
http://communities.intel.com/thread/...art=0&tstart=0
http://www.intel.com/support/chipset.../CS-031491.htm
Thanks
Jim
Old April 13, 2010, 07:29 AM
gingerbee's Avatar
the 9.6 drivers pass the trim command on know.
Old April 13, 2010, 07:33 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Hi GMJim, the newest released version does indeed pass the TRIM command. It will not pass it to raid'ed SSDs, BUT will to a single SSD even if their is RAID of HDDs on the system (there was an error in its reporting where it would show it passing it to Raid'ed SSDs. It does not. Just to non raided SSDs. In previous versions it would NOT pass the trim command if you had a raid of HDDs on the system even if you only had one SSD attached). Some peeps have gotten a moderate speed boost from using it compared to MS drivers. Easy enough way to check. Run Crystal DiskMark. AS SSD or another similar benchmark. Keep the results. Swap over to the new Intel ones. Rerun the benchmark. See if they improve. You should notice a minor improvement. It wont be earth shattering (or at least SHOULDN'T be) but every bit helps :)
Old April 13, 2010, 08:32 AM
Thanks everyone. I'm not really into benchmarking but I do want the system to run well. I just want to settle on a driver that I can rely on and not worry about maintenance. Do you think I'll have to use the toolbox even if I have this new driver?
Jim
Old April 13, 2010, 09:04 AM
AkG's Avatar
AkG AkG is offline
IF you run a ASHCI drive which can pass the trim command (like the latest Intel or default MS one) then there is no "need" to use the SSDToolbox. Couple nifty features in it, but to me the toolbox is mainly for peeps running older an OS that need to setup a manual trim (aka "optimizer") schedule. ;)
Old April 13, 2010, 02:06 PM
Well thanks again AKG. So I should be using the new Intel RST V9.6.0.10.1014 rather than the Win7 MS driver. Sometimes I think I should just stick to mainstream hardware but then I wouldn't learn anything!
Also I found this article. Interesting read about using a SSD in IDE mode.
http://benchmarkreviews.com/index.ph...temid=99999999
Jim
ROG HD4850 Matrix CazyJimKU Video Cards 10 June 28, 2009 02:51 PM
Storage question shayan288 Storage 10 June 27, 2009 07:59 PM
Watercooling an Asus 9800GT matrix...? Vegas Video Cards 1 January 20, 2009 09:12 PM
OC Info Matrix - Any Value to HWC? misterlarry Suggestions & Feedback 4 May 4, 2008 01:51 PM
Anyone tried the new Intel Chipset driver? Babrbarossa CPU's and Motherboards 0 May 3, 2007 09:49 AM
