Old February 5, 2010, 08:37 PM
biff's Avatar
Default What's tying up the resources?
How do I find out what is tying up my computer?... task manager isn't very specific.
From time to time the CPU usage will get pretty high when sitting idle even... 80% on one core and 30% on the other for instance. Those numbers are sorta picked out of thin air but are probably pretty close to accurate. But at that time task manager will only show a couple services using 2% or so and that's it.
The worst one is HDD usage. Every couple of hours the HDD will light up solid and everything comes to a screetching halt. Very annoying when I'm trying to watch a movie. I have to pause the movie and walk away for a bit and it usually clears in about 5 to 10 minutes. Task manager shows that svchost is using the HDD during that time. I've tried disabling indexing but that has had no effect.
System specs are:
E3110 on a Asus P5E-VM HDMI w/2GB of RAM and a Sapphire HD4670 running on Vista x86 and a couple WD 640GB drives. All stock speeds.
Thanks for any help!
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old February 5, 2010, 08:53 PM
Sushi Warrior's Avatar
Do you have shadowcopies or backups enabled?
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old February 5, 2010, 08:54 PM
MarkOne's Avatar
I read someplace one time, what was causing that.. but my bad memory do not remember witch Windows Services is responsible
but I notice something.
on Win7 if you disable the indexing ..the drive activity is not showing..
on vista.. I see the same steady led even with indexing disable.
was not looking far more because it's only my wife who use vista. for a light resource usage..
edit :
he have better memory than me
Old February 5, 2010, 09:11 PM
biff's Avatar
I don't know. I don't know what services those are... I'll have to look into it.
Asus P5Q-PRO
EVGA GTX 280 (SC?)
Sharing Resources Mysteryous Networking 2 September 22, 2007 01:06 PM
