Old February 3, 2010, 07:48 AM
Post EXCEL help
Hey guys!
Maybe somebody can help me here. I want to ''compare'' (an ''if'') but with two cells in Excel.
For example:
Cell: Value:
A1 20
A2 10
The thing I want to do is like the ''if'' founction in Excel:
IF(a logic test, [true answer], [false answer])
Now what I want:
IF(A2<A1, [A1], [A2])
This can't work in Excel because the true/false answers can't have cells in it.
What do I need to do this?
Thanks!
Old February 3, 2010, 07:55 AM
CMetaphor's Avatar
Perhaps a little more detail about what you're trying to do would help?
I don't understand your statement: "This can't work in Excel because the true/false answers can't have cells in it."
Something like this?
Old February 3, 2010, 09:19 AM
Yeah that's it! Exactly!
Old February 3, 2010, 09:22 AM
CMetaphor's Avatar
Well... it seemed to work for me? lol...
Just use the "forumala" button on the top (Fx) and click on the cells that you want to have in the IF statement once you choose it. Brings me back, good ol' excel.
Old February 3, 2010, 09:24 AM
It worked for you? I have 2007, do you? Maybe it does a difference. I'll post a picture... 2 secs
Old February 3, 2010, 09:32 AM
MarkOne's Avatar
Can it be than your excel see the , as a . I dough so but... I say so because I see you are from QC often we put french Canadian keyboard, when someone let it at English he often choose US regional setting . I always have to change the regional setting for that reason. it's a pain to put a "," instead of a ". "
but I fill I,m in the ditch with my idea... anyway
Old February 3, 2010, 09:49 AM
Well I'm not sure about that, because as you can see, in the help, they are telling me to put '',''.
So there you go guys:
The error message basically says that you can't have any letter, that maybe there is an invalid character or maybe the cell is in conflict...
Can't seem to know why it does this
Old February 3, 2010, 09:55 AM
MarkOne's Avatar
edit : you but [] , and CM don't , is there the problem .... I see a SI instead of a IF I think they put the [] in the exemple only to show you it's a cell reference , you don't include them
oups you error make me thing it's not so stupid, the help file is not adjust to the regional setting also. when you put a number like 1,00 do you have to put 1,00 or 1.00 ? it's woth to just go on the Control panel and change the keyboard regional setting and change for US if not set so , you don't need to change the language of the keyboard if you use a CF. just the regional setting,
Old February 3, 2010, 09:56 AM
your syntax is correct, but why is your B4 and B32 in [brackets]? take out the [] !
Old February 3, 2010, 10:01 AM
Seems the error was not about the commas or periods... Oh man thanks so much Starr seems the [] were messing everything up
thanks for help!
I can now finish this homework
excel - timetable for work CTA O/S's, Drivers & General Software 0 March 26, 2009 02:04 PM
