Old January 6, 2010, 08:57 PM
Default Shutdown Timer I Made
Hi Guys,
Shutdown Timer v3.0
Features:
  • Shutdown
  • Restart
  • Logoff
  • Lock
  • Hibernate
  • Standby
  • Monitor Standby
  • Open a File
  • Open a WebPage
  • Based on Date & Time
  • CPU/Memory Utilisation
  • CPU Temperature using Core Temp
  • Networking options
  • Process Management
  • Integrated Updater
  • Ability to save your settings for furture use
  • Completely Portable, You can take it on a USB if you want to!
  • 32 & 64 Bit compatible versions
Download and information here
Feedback would be great on it. Thanks
Old January 6, 2010, 09:28 PM
odis172's Avatar
new member.. with a link to a download?
Main Rig: Phenom II x3 720BE quad @ 3.2ghz - Gigabyte MA790GP-UD4H - 6 gigs ddr2 800 - EVGA GTX295 Co-op - Asus Xonar D2X - 2x 500GB wd raid 0 - PC P&C 750w - CM Stacker 830 Case - Samsung 24" - Logitech G15 keyboard - Logitech G9 mouse - Steelseries mousepad
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3 - 500GB wd Black - BT3.0/Intel 6300 Wifi - 9 Cell
Server: E5200 - Asus P5Q Deluxe - 3 gigs ddr800 - 4x Samsung F3 1TB - Perc 6/i - 2 x WD Black 500GB raid 1 - Compucase RA448A00
Old January 6, 2010, 09:36 PM
oops, if it's malware you may think is in the software then I can submit a virustotal request?
Old January 6, 2010, 09:54 PM
Infiniti's Avatar
I think he was talking about you being able to post links, despite being a new member. He probably didn't notice that you already had one post elsewhere though.
Anyway, welcome to the forums! Nice tool you got there, I'm sure it'd help some other members.
Old January 6, 2010, 11:30 PM
odis172's Avatar
I was just a bit suspicious of downloading a program from someone virtually unknown.
Anyways.
Old January 7, 2010, 05:12 AM
Anyways.
Oh right, I'm a regular member on Extreme Overclocking forums, just thought I'll give HCF a try
Thanks, hopefully can get feedback from it.
Old January 23, 2010, 03:13 PM
Shutdown Timer v2.5 Beta 2 has been released!
The main changes are a few GUI changes plus integration of Core Temp to allow you to take certain actions using the CPU temps.
There is now a 32 Bit and 64 Bit version, so users cannot upgrade their current version on the system if their OS is 64 bit.
Old January 23, 2010, 03:52 PM
Sushi Warrior's Avatar
I have a few suggestions. I would love a scheduled timer every day - I want my PC to go into sleep every week day at 12:00 midnight and wake up at 7:30AM. Can you either make a scheduled timer or even make it turn on at all?
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old January 23, 2010, 03:53 PM
You can't have a program that turns on a system, anything that turns the system on from boot will lay in the BIOS.
Old January 23, 2010, 03:54 PM
Infiniti's Avatar
Pretty sure you can schedule it to wake up though. I'm pretty sure he meant wake up from sleep.
PCI latency Timer Kyure Troubleshooting 3 November 7, 2009 03:43 AM
server AND pc stick on shutdown rob123 O/S's, Drivers & General Software 0 April 1, 2009 09:21 PM
New Build - First Timer ironguitar New Builds 5 October 10, 2008 02:47 AM
Quirky system crashing on a countdown timer Jadeonar Troubleshooting 10 September 7, 2008 08:56 AM
Shutdown after inactivity jnliten Troubleshooting 7 May 14, 2008 09:12 PM
