Old January 6, 2010, 06:22 PM
Dr_BenD_over's Avatar
Default Clock Proggy?
I'm looking for some sort of a clock proggy that can show the current time in the corner of the screen while playing a 3D game fullscreen (kinda like fraps does with the FPS). Is there such a thing?
Old January 6, 2010, 06:55 PM
Get a g15 keybaord... the LCD will display the time for yah =)
other then ^^^^ i dont know of a program that will work while in a game.
IM THE DUDE, PLAYING A DUDE, DISGUISED AS ANOTHER DUDE.
Old January 6, 2010, 06:58 PM
JD JD is offline
X-Fire? Though you'd have to bring up the X-Fire overlay, but it has the time, and works in the majority of games.
Easiest though is to just get a cheap clock for your desk
Old January 6, 2010, 07:09 PM
MarkOne's Avatar
I guess the OP is not stupid enough to buy a g15 only for a clock
Old January 6, 2010, 07:19 PM
martin_metal_88's Avatar
Maybe not Dr. but you know there is many people that will do;)
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old January 6, 2010, 07:25 PM
MarkOne's Avatar
Like buy an Asus Rog for the ability to use the LCD Post display as a clock
it's 20 minutes I look on Google nada , but why you need this Doc
Old January 7, 2010, 05:01 AM
I started playing Mass Effect again and I tend to loose track of time when I play, a quick 30min turns into 5hours. Maybe I'll build a clock...
Old January 8, 2010, 05:57 AM
A bit of scrounging, a few slight modifications, 1 backlit clock.
Old January 8, 2010, 01:15 PM
Nice .
Old January 8, 2010, 01:16 PM
Arinoth's Avatar
That is ing amazing man, hats off to you. You sir win for today
Computer clock, clone63 Troubleshooting 10 May 30, 2009 08:03 PM
Advanced Clock Control...? somecanadianguy Overclocking, Tweaking and Benchmarking 3 May 25, 2009 01:53 PM
Ready to Rock and Over Clock CasheKicker Overclocking, Tweaking and Benchmarking 5 April 29, 2008 11:25 PM
Pci-Clock help Dashock Troubleshooting 2 January 14, 2008 11:46 PM
Retrieving XSerial Number from Proggy? frosty Troubleshooting 2 December 16, 2007 09:53 AM
