Old January 5, 2010, 01:52 PM
Default Start Button and Taskbar problems. Win 7
Basically the problem is this. After using the two objects in question alot they kind of freeze (The little loading circle is there when you leave your mouse over the taskbar). You pass your mouse over the icons and they do not react. The only thing i have found that can help is either crlt+alt+delete to log ou or switch users and that just delays the inevitable. I have a OEM version of windows 7 Home Premium installed and I believe it might be the esplorer process that might not be working properly. How could I fix this?
sponsored deal, off button? Silvgearx Suggestions & Feedback 54 September 28, 2009 04:07 PM
Exttended Desktop not showing taskbar, icons etc. Cranky Video Cards 15 September 4, 2009 04:15 PM
power/reset button and cable magictorch Cases 2 November 28, 2007 01:09 PM
Missing thumb button for G5? No problem... cyberspyder Peripherals 7 May 1, 2007 07:24 AM
TaskBar Shuffle enaberif O/S's, Drivers & General Software 0 January 6, 2007 01:28 AM
