Old September 29, 2007, 12:14 PM
Default Alcohol 120% + Vista = nasal congestion
Last night I tried to install Alcohol 120% Build 308 on my friends Vista laptop. It installed but not without giving me this unknown publisher junk. It still installed ok, but vista blocked the program for security reasons even though i trust the program. How do I unblock the program. He wants to use the program to exercise his fair use rights but mainly so he doesnt have to depend so much on his flaky cd drive.
Thank you for your help.
Old September 29, 2007, 02:02 PM
Misoprostol
Guest
Posts: n/a
Use Daemon tools. Much better than Alcohol, and it's 120% FREE.
Old September 29, 2007, 02:17 PM
does it support .cue images?
example.bin: >800,000k
example.cue: 1k
Old September 29, 2007, 04:22 PM
JD JD is online now
Latest Alcohol 120% works fine here on Vista x64...
Version 1.9.6.5429.
Old October 2, 2007, 04:56 PM
but i dont have a key for that specific version. I have build 308 not build 5429.
Old October 2, 2007, 08:01 PM
JD JD is online now
Well use Daemon Tools or purchase the newer version of Alcohol.
Old October 3, 2007, 03:34 PM
Eldonko's Avatar
Hardware Canucks Reviewer
/agree daemon works 100% with vista 64, just DL the right version.
