Old September 27, 2007, 09:43 PM
belgolas's Avatar
Default Vista problems.
O.k. so why is it not letting me open programs that I have downloaded. It says it doesnèt have a digital signature. Is there a way to bypass this crap.
i7 2600K 4.6ghz, Asus P8Z68-V Pro 4 x 2 gigs of DDR3 1600 mhz, 160GB Intel SSD, 2TB black, 2TB back-up, 2TB media drive, 18x DVD burner, EVGA SLI GTX 480 SC (water cooled), G15 and G9 keyboard and Mouse, Alienware Optx 3D monitor, Corsair 1000w. Asus Xense, Corsair 800D.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old September 28, 2007, 08:15 AM
Are you using Vista64?
If so, Vista 64 forces driver signing. I would google it, might find a work around to it.
Q6600@3.2ghz
Asus P5N32-E Sli
4gb OCZ Platinum DDR2 @1100mhz
Antec P180
BFG GTX 260 Core 216
Corsair HX-620
Thermaltake Power Express 250W
Raptor150, WD 500gb. WD 300GB
X-Fi Extreme Music
Old September 28, 2007, 08:37 AM
sswilson's Avatar
Heavy handed DRM at its best...........
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
Old September 28, 2007, 09:10 AM
Unfortunately with the latest updates there was a way around it before but not now or that I've heard of.
Old September 28, 2007, 09:42 AM
b1lk1's Avatar
Vista Ultimate was supposed to be the version doing this. Turn UAC off and see what happens. My present experience with Vista Premium has been excellent. No problems at all, even using non signed drivers.
Old September 28, 2007, 02:57 PM
JD JD is offline
In Vista x64 the only way to disable driver signing enforcement is to hit F8 while booting and choose it (near the bottom of the list). You must do that every boot if you want it disabled. Otherwise unsigned drivers simply don't work.
I always disable UAC. I think I can manage not to open spyware/viruses myself. Not like I've ever gotten either unless I was doing it intentionally to play around.
Old September 28, 2007, 03:07 PM
belgolas's Avatar
UAC was almost disabled as soon as I had it installed. It is very annoying.
Sponsor a child!
Fight poverty.
Qoute by Perineum
Old September 28, 2007, 03:20 PM
While you can disable UAC its not really worth while to bother aside from removing the popup because you are still only a limited user to the system not a true Admin.
Old September 30, 2007, 11:11 AM
I tried adjusting the auto rwin settings in command prompt. To do so i had to be an admin. It kept telling me in command prompt. Disabled UAC+ defender. Voila I had full control of that.
3800X2@2.2GHz--2gb PC3200--200Gb Maxtor SATA2--eVga 8800GTS 320mb--eVga nForce4 SLI mobo--Klipsch 4.1--Antec nine hundred case w/Vantec 120mm on side--Vista Premium 64bit
Join our Folding@Home team!
Old September 30, 2007, 06:03 PM
Search for "command" then right click and choose "Run as Admin"
Big Problems Feff Troubleshooting 9 January 23, 2008 04:24 PM
Problems with overclock FritzGuy Overclocking, Tweaking and Benchmarking 6 December 10, 2007 07:14 PM
Problems Overclocking. Dethredic Video Cards 6 November 3, 2007 08:06 AM
More new problems! belgolas Troubleshooting 8 July 20, 2007 09:21 PM
Creative audio problems with Vista. cdn_Madrach O/S's, Drivers & General Software 3 February 28, 2007 10:40 AM
