Autocad 2010 Student ??????? Hello every one I want to play a little bit with autocad for make some parts with my friend CNC milling . of course I don't want to spend $ 4000 for see if I gone like make CAD, they said this version have full function, but print with watermark I don't care about it, but can I use the DWG in a CNC Milling ? here the link of the Student products Autodesk AutoCAD 2010 with Academic Discount at Studica.com |
You can't send a model straight to a CNC machine. You need to first generate tool paths based on the model, convert them into machine code, and then send that code to the CNC machine. I have no personal experience with AutoCAD, but I believe you can do that from within the software. |
I HIGHLY recommend Aspire to do what youve asked. Vectric - CNC Software Solutions - Wood Carving - Engraving - Signmaking - Routing - Machining It is very VERY easy to use for someone thats not very familiar with CNC and/or CAD. My buddy uses it on the home made CNC machine he built with my help. Wicked program, and its fairly cheap too. You can get everything you need to start milling in 3d for about $500 |
If you're a student, I thought you could download Autocad software for free? 1. What is the Education Community website? The Education Community is an online community where students and educators can download free* software, find valuable learning resources, and connect with people and jobs. To learn more, visit www.autodesk.com/edcommunity. Autodesk Education Community FAQ 12. How many times can a student download the product? The installation file(s) can be downloaded as many times as you want, but each Education Community member is issued only one serial number for that version in a 13-month period. Without a serial number, the downloaded file will work for a 30-day trial period. |
Thanks guy, the Vectric look more simple than autocad.. but I think I don't make my question clear. I want to know if with the Student edition I can make DWG that I can export in a software for milling like in the exemple of Sagath , the Cut2D of Vertric If yes an I can do what wants and start to like it I don't care after to purchase the Autocad full version. So is it worth to spent $ 200 in a student Autocad. or it's just a demo |
And again, V-Carve will take any drawings, export it to G-code for CNC machines, and run it. It will also take scans, jpgs, bmps and a bunch of other drawing types, and make the G-Code for that. AUTOCAD itself will NOT do G-Code, unless you buy an addon, and even then, I dont think the addon works with the student copies. |
Thanks Sagath, I really appreciate your link , by the way the autocad show in the link is good for 60 months , If I use it and save a DWG MAY be I can use V-carve after for the milling, anyway they offer a 30 days free version for try,.. that's nice . But the fact it also draw a watermark make me worry that I can't use it for that purpose. But I really want to try Autocad . So I think I gone risk the Student for play a little bit with it, One thing sure I will try the Vectric free trial to see what I can do with it , anyway I need something also for the laser cutter I plan to purchase. thanks again for that link |
So in short, you should be able to use the student version of AutoCAD to do what you want. |
I guess it'S you who don't understand... I said I will export the drawing in a software like cut2D , not directly in the CNC . my friend have the software to generate the code , I just need to bring him a drawing in .dwg but I'm worry if you have a watermark in the drawing it will also show in the code ... Anyway I was expecting someone who have do it , not guess it. Since I really want learn Autocad I will order the student version, and at the end if I still like it I will simply order the full version. I don't need to make the coding, every machin shop have thje software to do so , I just need to export the drawinfg in dwg Quote:
| All times are GMT -7. The time now is 10:59 AM. |
