Originally Posted by MarkOne what is the best, scrapware free of course |
I really don't know what would qualify as best, but iTunes will do it for you.
Find the iTunes preferences and look under the "general" tab for the "Import settings..." button. Choose what format you would like to import your files into (in this case I imagine it would be the MP3 encoder) choose a setting and click ok. Click ok one more time to close your preference window. In iTunes, find your m4a files in your library or import them in. Right click on a file and choose "Create MP3 version" from the pop-up menu. You should be able to do this for a bunch of songs at once, even.
Again, maybe not the "best", but I wouldn't call iTunes scrapware, even if you didn't like it very much.
