Old December 3, 2009, 04:44 AM
Dr_BenD_over's Avatar
Default The battle begins - Win7 x64
So, I'm giving this a shot at work, this should be fun, we've got so much crappy half-assed inhouse software, and I have to use most of it on a daily basis.
Issues so far:
- no drivers for my FlashPro430 (not a show stopper, I can use my Win2K machine)
- shortcuts to network drives on the desktop keep disappearing - very annoying - this may be due to a bios issues with the Vostro's which makes them loose network connections
- I keep having to log into forums again, I'm sure this is some setting somewhere
- I could not copy key DLL's to the system32 directory, it said I needed to be an administrator to do so, but I am, I had to completely disable UAC to get by that, and of course I actually wound up having to put them in the system directory to get the software to work
- Cygwin doesn't want to run, I got it to work once, but now I just get errors - looks like something to do with memory allocation, I'm trying to get a new installer now that works with Win7, but it seems all those mirrors are craptacular. I've gotten this to run, kinda. I'm getting a error that the username and pasword isn't setup properly (on a domain) but when I try to create the group and password using mkgroup and mkpasswd, I get an error that the RPC server is not responding, I've enabled the RPC locator to no avail.
- MS's drivers for my Aardvark didn't work, fortunately it uses a bog standard interface and I was able to find drivers elsewhere, it remains to be seen as to whether it works with our software though - and it doesn't
Surprises:
- Both CE 3.0 (serial) and CE 5.0 (USB) devices will connect to WMDC
more to follow, I really don't want to go back to XP
If it's stupid and it works, it isn't stupid.
Old December 3, 2009, 06:00 PM
JD JD is offline
Use the XP Mode functionality if you have Professional/Ultimate and that might help out with application compatibility. Not sure about drivers though.
Old December 8, 2009, 11:59 AM
Looks like I'll be sticking with Windows 7, I can use an old Win2K machine for the stuff that doesn't work on Win7 yet. Cygwin's still not 100% sorted out, but I've figured out work arounds for what I need to use it for.
Old December 8, 2009, 12:05 PM
Chilly's Avatar
Other than these minor issues, how are you liking it so-far?
"Let's face it, we're not changing the world. We're building a product that helps people buy more crap - and watch porn."
Bill Watkins, CEO Seagate Technology
Dual Xeon X5650 @ 4.1GHz | EVGA Classified SR-2
2x4GB G.Skill at 1496MHz (9-9-9-24) | XFX 4890 XXX 1GB at 1000/1000MHz
Intel SSD X25-M 80GB Gen2 | Western Digital 1TB Black | SilverStone Zeus 1200W
Sound Blaster X-Fi XtremeMusic | Sony MDR-V700 | Windows Seven x64
Stuff for Sale! You must buy it, you can't look away!
Old December 8, 2009, 12:22 PM
It's pretty decent, I can't wait to get it on my gaming machine, which shouldn't have any issues, and I can finally be rid of Vista. I am missing Nview though, I'l have to see if I can get that to work.
Old December 9, 2009, 05:23 AM
May have spoke to soon. "COM Surrogate Failed" as I right clicked and clicked personalization, then when I sought an online solution for the issue I got a RPC failure to iexplorer.exe
Old December 9, 2009, 07:18 AM
Gellidius's Avatar
about this:"-shortcuts to network drives on the desktop keep disappearing - very annoying - this may be due to a bios issues with the Vostro's which makes them loose network connections",
i had the same problem, found the solution by changing config. in ccleaner.
Jacques
Ego cogito, ergo deus non est.
Old December 9, 2009, 08:33 AM
Seems Corel X3 has some issues as well, it keeps telling me I can't make changes to a network drive when I go to save a file, but it's my local drive.
Old December 9, 2009, 09:50 AM
bahaha xp 4 lyfe.
sorry i know not helpful :p
Old December 9, 2009, 02:00 PM
Holly Cow.. Doc you're really encountering issues after issues.. I swear, even though I don't do as much as you do (based on software), I seriously am still to encounter one error, or problem.. Yes some things are hard to get used to, but still, slowly but steadily..
I'm yet to experiment the XP Mode.. Also in gaming, for some reason before I formatted and installed Win 7, by XP 32 bit.. some games kept lagging in games where places have heavy graphics usage.. Imo for a 4870 to play games like Colin McRae Dirt or Nba Live 07.. Live 07 I actually installed a major update that really improves grahpics, visuals, the courts.. but sometimes it used to lag, in Win 7 now.. I hardly ever have lagging, it plays smooth..
Anyhow, hope you get your issues sorted out.. I am still a die hard XP fan, but starting to like Win 7 too..
Switching my Notebook to Win7 x64 Ultimate, SSD recommendations? AERo Storage 15 November 27, 2009 10:23 AM
I7 x64 or XP x64 for gaming PC? Georgian New Builds 9 November 1, 2009 11:28 AM
Starcraft 2 - Battle Report 4 Spaceman-Spiff Gaming 14 October 23, 2009 07:41 AM
Vista x64 / Win7 x64 + 4gigs ram = Which TV tuner (Shaw Digital : Vancouver) KylSp HTPC Systems & Software 7 June 18, 2009 02:13 AM
Starcraft II battle report 2 Alwaysrun Gaming 22 April 30, 2009 12:17 PM
