Old December 9, 2009, 03:33 PM
Chilly's Avatar
At this point, it sounds like your install has become corrupt or some sort of hardware is causing issues(either because of incompatibility, or faulty). Your having too many issues unrelated to software compatibility issues(RPC failing, COM failing, etc).
What kind of system was this that you put it on? I can tell that its not a usual "home" configuration by the way your talking about it. Specs?
Old December 9, 2009, 03:57 PM
Dr_BenD_over's Avatar
Fallen Folder
It's pretty much a bone stock Dell Vostro 420, I just slapped a 9800GT in it and a Sammy DVD±RW - and removed a whole lot of crapware. It was kinda flakey before with XP Pro (downgraded from Vista business)
All's well that's Haswell
Old December 10, 2009, 05:46 PM
Dashock's Avatar
haha thats hilarious i was just going to come on and be like I made the move to 64 bit Windows 7 after my stupid audio driver problems only to find out others beat the punch.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
Old December 10, 2009, 05:49 PM
Dashock's Avatar
I havent had too bad issues just finding it out they have not made a firefox 64 bit edition im currently installing all my programs. Again ran thru a problem with Asus software specificallyh EPU-6 which i use to downclock when im just browsing and since i use it alot i wanted it but i found a newer version then the beta one supplied on Asus website and its working fine. So far i can say its pretty cool and btw guys it only costed me 50 bucks with the DVD theres a promotion if yer in school i can give you the website.
Asus P5Q-E
Corsair Cx600M
Old December 10, 2009, 09:52 PM
Dashock's Avatar
Anyone else finding the Search function in Win7 a little bit more confusing then it should be i prefer the xp interface i wish there was a way to set it where it does not search only the library first but the harddrives?
Asus P5Q-E
Corsair Cx600M
Old December 11, 2009, 04:53 AM
Fallen Folder
I couldn't find the search at first
Old December 11, 2009, 05:06 AM
Fallen Folder
Code:
Log Name:      System
Source:        Service Control Manager
Date:          12/11/2009 7:59:49 AM
Event ID:      7000
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      ************
Description:
The Diagnostic Service Host service failed to start due to the following error:
A privilege that the service requires to function properly does not exist in the service account configuration. You may use the Services Microsoft Management Console (MMC) snap-in (services.msc) and the Local Security Settings MMC snap-in (secpol.msc) to view the service configuration and the account configuration.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
    <EventID Qualifiers="49152">7000</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8080000000000000</Keywords>
    <TimeCreated SystemTime="2009-12-11T11:59:49.649661500Z" />
    <EventRecordID>19176</EventRecordID>
    <Correlation />
    <Execution ProcessID="520" ThreadID="4196" />
    <Channel>System</Channel>
    <Computer>************</Computer>
    <Security />
  </System>
  <EventData>
    <Data Name="param1">Diagnostic Service Host</Data>
    <Data Name="param2">%%1297</Data>
  </EventData>
</Event>
WTF, 135 instances in the past hour.
Old December 11, 2009, 05:18 AM
Dashock's Avatar
i wish i knew what that window said lol where did yu see that?
Asus P5Q-E
Corsair Cx600M
  #19 (permalink)
Old December 11, 2009, 05:30 AM
Fallen Folder
11468 occurances in the last 7 DAYS.
Our IT guy was quick to say he wasn't having this problem with Win7, but when I told him to check the logs, he's been getting it as well
  #20 (permalink)
Old December 11, 2009, 05:38 AM
Dashock's Avatar
how do i check that?
Asus P5Q-E
Corsair Cx600M
Switching my Notebook to Win7 x64 Ultimate, SSD recommendations? AERo Storage 15 November 27, 2009 11:23 AM
I7 x64 or XP x64 for gaming PC? Georgian New Builds 9 November 1, 2009 12:28 PM
Starcraft 2 - Battle Report 4 Spaceman-Spiff Gaming 14 October 23, 2009 07:41 AM
Vista x64 / Win7 x64 + 4gigs ram = Which TV tuner (Shaw Digital : Vancouver) KylSp HTPC Systems & Software 7 June 18, 2009 02:13 AM
Starcraft II battle report 2 Alwaysrun Gaming 22 April 30, 2009 12:17 PM
