Old December 2, 2009, 07:23 AM
MarkOne's Avatar
Default Question about Foxit
hi everyone, I start to find this Adobe Reader very heavy , so I want to know if you have good experience with Foxit.
Old December 2, 2009, 07:48 AM
Supergrover's Avatar
I'll never use adobe again.
R.I.P.
Old December 2, 2009, 07:57 AM
Neolithium_Wpg's Avatar
I love my foxit! :)
MacBook Air 13" (2011) | Blackberry Bold 9900
A Veteran, whether Regular Force, Reserve or Retired- is someone who, at one point in their life, wrote a blank cheque made payable to the Dominion of Canada for an amount of "Up to and including my life"
-Author Unknown
Old December 2, 2009, 07:58 AM
MarkOne's Avatar
Good ...download started
Old December 2, 2009, 10:44 AM
Yep, it's a good program. Been using it for years instead of Acrobat.
Old December 2, 2009, 11:38 AM
Spaceman-Spiff's Avatar
I used Foxit for over a year. I liked it cause it's light and fast.
But just recently, I found that functionality wise, it's not as great as Adobe Reader. I was having a hard time copy/pasting some texts in table/multiple columns so I switched back to the latest Adobe Reader. The newer Adobe Reader version seems pretty fast too, not as bad as the older versions.
Old December 2, 2009, 12:36 PM
burebista's Avatar
What is Adobe Reader?
If it ain't broke... fix it until it is.
Old December 2, 2009, 12:40 PM
gingerbee's Avatar
never used foxit thank for inadvertent info
Old December 2, 2009, 12:49 PM
Jake_HT's Avatar
I like... however firefox likes to crash sometimes when I open PDFs with it... never used to do that.
http://jakeht.deviantart.com/
Old December 6, 2009, 01:23 AM
CroSsFiRe2009's Avatar
Got some errors with foxit but its fast but it also seems the new adobe is fast ..finally
