<~----> Which firewall you use??? - Hardware Canucks
Old September 4, 2007, 06:06 PM
ebdoradz's Avatar
Default Which firewall you use???
which on do you use???
look at those test
Leak-tests results - matousec.com
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 512mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
Old September 4, 2007, 06:17 PM
magictorch's Avatar
Default thanks fo this
ow i use sygate personal firewall and its crap!! CNET gave it a good review. Time to switch, this is a very useful link. nice job.
Old September 4, 2007, 06:53 PM
Software firewalls are crap. Invest in a good router or old 486 computer and setup your own firewall and rules.
Old September 4, 2007, 07:09 PM
sswilson's Avatar
Yeah, with a router in place, all you are really worried about is "outgoing" traffic, and even the windoze firewall handles that now.
Old September 4, 2007, 07:18 PM
magictorch's Avatar
Default cheap router
better start looking
Old September 4, 2007, 07:26 PM
What do you have outgoing that you are so worried about? I never understood that.
Old September 4, 2007, 08:04 PM
sswilson's Avatar
I don't have any outgoing, but the issue would be a piece of malware which somehow managed to install itself and was either sending personal information out without your knowledge, or being used as a zombie system.
Without a firewall blocking outgoing most folks would have no idea that their system was compromised.
Old September 4, 2007, 08:14 PM
Supergrover's Avatar
Router, windows firewall, good enough:)
R.I.P.
Old September 4, 2007, 09:03 PM
lcdguy's Avatar
I currently use a hardware router/firewall made by netgear's prosafe line. I also your CA Antivirus/ Antispyware-Malware
Old September 4, 2007, 09:36 PM
Gav's Avatar
Gav Gav is offline
Administrator
Excellent link.
I also like this site. It hosts a a whole range of useful leaktest and hole plug-up tools as well as the ultimate HDD recovery software, Spinrite!
Home of Gibson Research Corporation
