Old October 23, 2009, 01:03 PM
Default Vista WMP crashes when playing audio files.
Whenever i try to play an audio file (whatever format) the player crashes right away. But movies work. I torrented Halo 2 and it required some heavy stuff to be done around the windows and im afraid i might have damaged something. So, what would make WMP possibly act like that?=
Old October 23, 2009, 01:08 PM
Perineum's Avatar
WMP likes to die, it seems. I wouldn't think it has to do with your torrent.
You either need to do a repair install or you've got a hell of a lot of reading ahead of you.
Old October 23, 2009, 01:25 PM
Repair - Ill try.
Reading - Nooooooo!
Edit: where can i find the repair option? WMP isnt in Programs and features. Thus reinstalling is not an option since i cant uninstall it. The Program Files WMP isnt much use either.
EDIT: and the torrent made me change things and privileges in System32 folders and such. Wus all kindsa warnings that i might damage my system and stuff.
Old October 23, 2009, 01:55 PM
sswilson's Avatar
Ummmmm....... why would a torrent need access to your system files?
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old October 23, 2009, 01:57 PM
To modify dll files. I needed to modify them. Replace and all. Had to grant myself full access through properties and it warned me about me being able to cause damage.
Old October 23, 2009, 01:59 PM
How do i repair WMP can some1 tell me pls!
Old October 23, 2009, 07:36 PM
No offense but if a downloaded game is expecting you to modify important system files it's likely that the hackers / crackers are giving bunch of unwanted surprises along with the game.
I hope you know you're in for a LOT more problems than a crash-happy Windows Media Player. Your OS install is likely to self-destruct if you try to install any updates to Windows (if it doesn't bring itself down with viruses and the like).
If it was my computer, I'd zero-pass my hard drive and reinstall the OS, but I assume you don't want to do that...
Before we can help, you will have to undo all the damage that torrent has caused. If you went around replacing things in \System32\ I am certain that there are a lot more Windows features that are not working. Do you have a System Restore point from before you followed the instructions in the torrent, or will you be able to replace all the DLLs?
Old October 23, 2009, 09:49 PM
Perineum's Avatar
What were the instructions that came with the torrent? Post them here for us to see...
Also, the repair install requires the disc and won't be found in "add/remove programs" or whatever the hell MS is calling it this week.
Need to reinstall WMP 11 biff O/S's, Drivers & General Software 14 June 2, 2009 07:07 PM
Audio and Video skipping during playback WMP and Nero Showtime Eagle Eye Troubleshooting 3 September 17, 2008 01:39 PM
Audio Device Management - Vista encorp Audio 10 June 14, 2008 01:33 PM
Growl!!! BF2142 Crashes in VISTA CMetaphor Gaming 5 June 6, 2007 10:42 AM
Creative audio problems with Vista. cdn_Madrach O/S's, Drivers & General Software 3 February 28, 2007 10:40 AM
