<~----> cpuz and core temp errors? - Hardware Canucks
Old October 22, 2009, 06:45 PM
Default cpuz and core temp errors?
Greetings all, I'm getting some different readings from cpu-z and core temp for my cpu clock speed. My current speed is 3.2Ghz in bios (400X8). However, both programs are jumping back and forth between 400X6 and 400X8. Is this normal? Is anyone else here experiencing this?
Old October 22, 2009, 06:52 PM
Arinoth's Avatar
What's Real Temp say?
Old October 22, 2009, 07:10 PM
Silvgearx's Avatar
it might be the intel speedstep.
is your EIS disable in bios?
Old October 22, 2009, 07:15 PM
Sushi Warrior's Avatar
It's speedstep. Mine does the same, not sure why it's switching (can't make up it's mind???) but I'm pretty sure (read: 90%+ sure) that's what it is.
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
Old October 23, 2009, 01:57 AM
I had speedstep disabled in bios. The odd readings disappear as soon as I run prime95. No biggie I guess.
Old October 23, 2009, 05:23 AM
Caldezar's Avatar
For sure it's speedstep if it disappears when running prime95. It's whole purpose is to save power when not under load.
Old October 23, 2009, 05:29 AM
But speedstep is disabled in bios.
Old October 23, 2009, 06:32 AM
Arinoth's Avatar
Sounds like speedstep i still creeping in. Are you 100% its disabled in the bios ?
Old October 23, 2009, 08:06 AM
100% sure it's disabled. It's the first thing I disabled on the first boot last night after final assembly of the Green Machine.
Old October 23, 2009, 01:02 PM
Any other power saving features enabled?
CPU temp vs Core temp phil3_66666 Air Cooling 4 July 31, 2009 09:39 PM
Q9650 Core speed in CPUZ Maculosa Troubleshooting 7 February 23, 2009 05:06 PM
Real Temp or Core Temp ?? FrankyG Overclocking, Tweaking and Benchmarking 11 September 29, 2008 11:24 PM
Core temp's ? Unklmo CPU's and Motherboards 18 August 23, 2007 02:18 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
