Old October 20, 2009, 08:20 PM
Default OOPS!
I am currently running XP on my old PC and my new i7 rig is in the mail and will arrive on friday. WooHoo! I was going to load my oem xp on it till I can get a copy of Windows 7. After some reading I discovered OEM is linked to my MB. Is there any way I can work around it or am I SOL till I can get a copy of W7. My Niece is going to get me a copy through UBC but there is no news yet on the discount they get. It will drive me nuts not being able to use it.
Old October 20, 2009, 08:24 PM
sswilson's Avatar
Is it a stand alone OEM, or is it something from a "big box" build (like acer / HP / compaq / etc.....)? If it's a stand alone OEM, it will probably install fine.
Old October 20, 2009, 08:58 PM
It's a stand alone. It is a HP computer but I got tired of the 7 discs it took to repair the OS so I got a cheap OEM copy of XP off of ebay. If it does load is it possible to get an upgrade to W7 PRO retail or would that not work to go from OEM to Retail
Old October 20, 2009, 10:22 PM
Technically the license doesn't allow you to use it on a different machine than the one it was first installed on. However, practically speaking, you can still use it without any problems, although you will technically be violating the EULA.
Oops JMCD Air Cooling 2 July 3, 2009 05:12 PM
Oops! I think I made a mistake, guys! HermesĄ˘ New Builds 17 December 25, 2008 12:40 AM
