What's the operating system? If it's Vista then when you initially connect using wireless it'll ask you "what type of connection is this... "Home, Private, or Public" when you first connect. It's not quite the same thing as setting it up as "lan" and unfortunately I'm not sure where windows hides that setting once it's set. It's not related to the physical connection (as your "lan" would be), it's related to connection security settings and sets the level of things like file sharing based on the "type" of connection.
Try changing the ssid to force a new connection and see if it offers you that choice for the "new" connection.
__________________ ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 / MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF |
