Originally Posted by SKYMTL It is XP.
However, on the computer I have WiFi and wired LAN working without an issue. It is just Outlook that doesn't connect when use it over wireless. |
Did you try changing the ssid?
My money's still on something security related based on the "catagory" of connection. If you can connect and surf via wi-fi and you can send email through the same router when you connect via ethernet cable then all of your ports are set correctly. I suppose it's possible to block the ports in the router for just the wireless connections, but it certainly wouldn't be the default.
The only possible difference is that either windows or office thinks that it's not a secure network and is blocking email over wi-fi.
__________________________________________________ ________
Are you running any security software? Might be a setting in there related to it as well. Try turning off any firewalls you have and see if that allows you to send email via wi-fi.
How about your wireless connection port settings?
control panel (classic view) / network connections / right click on the wireless network connection / select properties / general tab / in the second box highlight "internet protocol (TCP/IP) / select properties / General tab / select "advanced" / options tab / Highlight "TCP/IP filtering" / select properties / ensure that "enable TCP/IP filtering (all adapters)" isn't enabled (the settings below only matter if that box is checked).
I doubt this is the issue as I'm pretty sure that it's global over both the wired and wireless connections but it wouldn't hurt to check.
__________________________________________________ __________________
Did you try setting up OE to see if it will work? That'll point directly to security settings in Office 2007 as the culprit if OE works and Outlook 2007 doesn't.
Office 2007 has a lot of funky filtering / security settings that many folks have been having issues with.
