Old September 26, 2009, 03:14 PM
Default 32bit vs 64bit
Hi, I just built my PC and I'm looking for an OS.
Gaming wise, is 64bit a big upgrade from 32 bit?
thanks
Old September 26, 2009, 03:40 PM
gingerbee's Avatar
no. jmo
Old September 26, 2009, 03:42 PM
Perineum's Avatar
If you have less than 4gb of memory then definately don't look at 64bit
Old September 26, 2009, 04:22 PM
Arinoth's Avatar
If you have less then 4GB of ram installed in your computer then you gain no advantage in 64bit over 32bit. 64bit just allows your computer to address more then 4GB of ram
Old September 26, 2009, 04:28 PM
muse108dc's Avatar
If your computer can handle 64bit (my laptop cant for example) then it is worth while getting. It doesnt matter how much ram, or infact anything else. 64>32
Old September 26, 2009, 04:34 PM
ah ok thanks.
I guess Ill get a 64bit cuz ill prolly get 6gigs of ram later
Old September 26, 2009, 05:04 PM
JD JD is offline
Yeah I wouldn't suggest buying a 32bit OS at this point, unless your CPU doesn't support 64bit.
64bit is quickly becoming the standard now. Most OEMs are already using x64 Vista, and I'm sure they'll carry over into Windows 7.
Old September 26, 2009, 05:39 PM
headsh0t's Avatar
Unless you use a netbook.
Old September 26, 2009, 06:01 PM
Airshehan's Avatar
Yeah, don't get a 32-Bit OS, I'm a gamer and I use 64-Bit Vista Home Premium with 6Gigs of RAM and it works like a dream!
Dell XPS 630i / Intel Core 2 Quad Q9300 @ 2.67GHz / Stock Cooling (Temporary) / 6GB DDR2 800 RAM + 4GB Windows ReadyBoost/ Nvidia GeForce 9800 GT / Samsung SpinPoint 640GB + Seagate FreeAgent 250GB / 750W PSU / Nvidia Nforce 650i SLI / Logitech X-235 Speakers + Plantronics .Audio 370 Gaming Headset / Dell 22' E228WFP / Razer DeathAdder /Windows Vista Home Premium 64-Bit
Airshehan
Old September 26, 2009, 07:48 PM
Having 4GB+ RAM isn't the only reason to go with a 64-bit o/s. Multicore processors will be utilized to their full potential since they are 64-bit and certain data encryption routines can be handled better. At a hardware level it would be better to go 64-bit as long as their are drivers to support it.
As for games/apps there can be some improvement in performance in relation to hardware but generally the software needs to be specifically written for 64-bit.
Imo, go with 64-bit to be future proof.
System Spec Peripherals: Corsair H70 cpu cooler (w/ 2 120mm Scythe Gentle Typhoon 1850rpm fans) | Zalman MFC3 fan controller | Gigabyte Aivia Osmium kb | Steelseries Sensei mouse | Logitech Z-2300 2.1 speakers | SteelSeries SX mouse surface
For the real serious stuff: 2.53GHz Mac Mini | 4GB DDR3 1066 RAM | 320GB HDD | Samsung P2250 (x2) | Apple Magic Mouse | Apple Magic Trackpad | Apple Wireless KB | Drobo FS 6.5TB
Laptops: Dell XPS M1530 | Asus G74SX-DH71
Surface Pro 128GB
XP-64bit or Vista-64bit or Windows 7 beta?- new gaming rig Ruff_Ryda New Builds 13 April 25, 2009 05:54 PM
XP? Vista? 32bit? 64bit? 7? RainMaker O/S's, Drivers & General Software 30 January 13, 2009 06:08 PM
Vista 32bit or 64bit for gaming cndian O/S's, Drivers & General Software 54 December 10, 2008 05:47 PM
32bit Vs 64bit XP enzeo O/S's, Drivers & General Software 6 September 28, 2007 01:53 PM
Vista 64bit vs. XP 32bit 4GB RAM bench comparo Eldonko O/S's, Drivers & General Software 13 May 14, 2007 01:09 PM
