-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Can you install operating system to external hard drive. (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/23357-can-you-install-operating-system-external-hard-drive.html)
JORD4N September 20, 2009 06:24 PM
Hello there im in the process of my build but i have not finished yet so i want to pre install w-7 to my sata hdd through my laptop.
I have connected the sata hdd to my laptop but how would i go arround install windows 7 just to that sata hdd (external) :thumb:
Thanks :biggrin:
I would like to do this so as soon as the i7 and x58 arrives i get straight into gaming and no worry about install games/windows ect :thumb:
enaberif September 20, 2009 06:29 PM
As long as the external enclosure is eSata you'l be fine.
SugarJ September 20, 2009 08:28 PM
You'd probably have to re-install anyways, because your laptop has different chipset drivers than your X58. It's not impossible to workaround in XP or Vista (boot to safe mode on old system, delete drivers, move drive to new system, boot), but I've never tried it on a Windows 7 install, and for the 20 minutes it takes to install 7 on a HDD, it's probably not worth your time.
Perineum September 20, 2009 08:34 PM
I've moved Vista drives very easily....
Rip the Vista containing drive out of old machine...
Install in new machine and boot up....
Stare lovingly at the black screen that Vista will boot up into...
Come back in 15 minutes, but keep watching the HD light.... (it's installing drivers!) When HD light slows significantly or stops completely....
Restart machine using: "Windows key" -> "U key" -> "R key" -> "K key".....
When Vista restarts it'll have readjusted itself to the new machine and boots sucessfully.....
Enjoy....!
At least, this is what I've found :thumb:
gingerbee September 20, 2009 08:38 PM
why not just load the drivers before you pull it out of the old machine and when you boot up the new machine vista/7 will load the right drivers for the hardware
xs1t0ry September 22, 2009 06:26 PM
If ever you are interested, Linux can be installed to pretty much any machine with a HDD, from Xbox and PS3 to supercomputers and smartphones.
:D
