Old September 16, 2009, 11:04 AM
Default Syncing program
Hello,
I would like to get an app so I can sync some folders between my PC, netbook, external HDD. Can anyone give me a suggestion?
Thanks!
Back up - Ebay (Inik1) or Heatware
Old September 16, 2009, 11:27 AM
anelectricmind's Avatar
Originally Posted by Inik View Post
Hello,
Thanks!
You can do it on the net by using Dropbox. 2Gb of free space. You install a small client application on both your PC and netbook. Then, It's just a question of dragging and dropping your files in the Dropbox folder.
Or you can use Microsoft SyncToy 2.0. Very basic application to synchronize between 2 folders. I have never tried it over a LAN though.
Old September 16, 2009, 02:10 PM
I just installed Dropbox and it's working great! I also installed DirSyncPro (open source app) to sync some folders with my external HDD. Thanks for your input!
Conversion Program SiDiX007 O/S's, Drivers & General Software 5 May 16, 2009 06:56 PM
Best program to overclock an AMD X2 Gooses Overclocking, Tweaking and Benchmarking 7 April 22, 2009 06:05 PM
i need help finding a program EaGle1337 Off Topic 0 January 26, 2009 05:37 PM
program Rapid-X O/S's, Drivers & General Software 8 September 3, 2007 06:13 PM
CS:S ti normal program Long John Silver Gaming 5 June 21, 2007 07:32 PM
