Old August 24, 2007, 07:46 PM
Misoprostol
Guest
Posts: n/a
It used to be (in Canada anyway) that if you called the toll number it would connect you to the live operator right off the bat. Now both the toll-free one and the toll number take you to the robot. If you play dumb and mash the 0 key the robot will forward you to a real person.
Old August 24, 2007, 07:57 PM
Supergrover's Avatar
Thanks for the tip MISO, added it to the first post. ;)
R.I.P.
Coolit rolls out new product line Babrbarossa Press Releases & Tech News 1 January 6, 2008 09:08 AM
