Old September 1, 2009, 01:25 PM
Default Installing Win98SE on a sata machine
Hi guys,
Just as I'm thinking about moving to Windows 7, I need to install Win98 to a Acer Aspire AX1300. Unfortunately, I can't find sata drivers. So, I boot on the WIn98 boot cd, choose the installation option. Then it says that it can't load the cd-rom driver (cuz it's a ide driver and the cd-rom is sata). So I guess I'm stuck as long as I don't find a sata driver.
Anyone has one?
E8400 | Xigmatek HDT-S1283 | GA-EP45-DS3L | OCZ XTC Platinum Edition PC2-8500 4X2GB | HD 4890 1GB | Corsair Tx750W | Samsung 245BW | WD 1TB Caviar Black | Turtle Beach Ear Force X-52 | Antec Three Hundred
Old September 1, 2009, 08:53 PM
JD JD is offline
As far as I'm aware, 98 does not have SATA/SCSI support.
If you need to run 98 for whatever profound reason, just use virtualization within Windows 7. Grab something like VirtualPC or VirtualBox.
Old September 1, 2009, 08:55 PM
chrisk's Avatar
Folding Captain
Is there an option in the bios to set the sata to IDE mode?
Fold for team #54196
Old September 1, 2009, 09:24 PM
Headaches.....
Old September 1, 2009, 09:27 PM
99% of motherboards that have SATA ports have "IDE Emulation" mode which allows an operating system to see a SATA port as a IDE port.
Old September 2, 2009, 05:37 AM
JD JD is offline
I still imagine you're going to have a ton of issues getting it up and running even if you get it installed. I highly doubt it supports any of the hardware in that PC, and getting drivers is probably impossible too. Thus why virtualization would probably end up being just as fast or faster since you'll just be using generic drivers.
Old September 2, 2009, 06:20 AM
the "ide emulation" doesn't allow me to start the windows installer...
Old September 2, 2009, 08:16 AM
Unknownm's Avatar
I believe windows 98 memory limit was 512MB due to a bug, over that it would tell you "not enough memory" which is pretty ironic
Old September 2, 2009, 09:00 AM
Id say just go with a virtual machine and save some time and headaches.
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
Old September 2, 2009, 01:44 PM
I went your way and tried to set up a VM. I'm wondering why vm emulate hardware that is not supported by the drivers onto the windows cd....
Damn, i still must find the win98 drivers :(
Drive image of win98se on a usb drive Jonwall O/S's, Drivers & General Software 7 May 26, 2009 03:32 PM
[FS] WTT/WTS DVD's for cash/sata optical drive/sata hdd's/ Geforce 9800 or better The MAX Buy/Sell & Trade 4 April 16, 2009 04:22 PM
Machine burnt out. New machine needed Neutronium New Builds 15 March 18, 2009 12:23 AM
WD 640 Black SATA ....Not SATA 2 rjbarker Storage 10 January 19, 2009 11:40 PM
Installing windows, SATA prob miggs78 Troubleshooting 12 September 5, 2008 05:44 PM
