Old August 24, 2009, 06:12 PM
Exclamation Cant delete this file!!! HELP!!
Hey guys, i downloaded a "movie" and extracted to my Desktop. And it was corrupted (the size is 0 Bytes), so I m trying to delete it. I just cant.. I tried win7, xp, nothing... this is the error message when i try to delete and/or rename it
I tried to delete it from MS DOS, but still cant.
Ok, then, i extracted the same file again into TRY folder, and now i cant delete that folder again... HELP!!! is it a virus? i scanned it using Avast and it didnt detect. There's one thing that is odd though, the file name has ":" inside it, do you guys think it's the reason?
Old August 24, 2009, 06:22 PM
element291's Avatar
unfortunately thats what happens when your a porn addict.
- try ctrl+alt+delete and see if there are any weird processes.
- end them and pray they dont automatically pop up.
- try deleting files
option 2
- goto run, type 'msconfig'
- then uncheck any processes or applications that you dont recognize
- restart
- attempt deleting files
If its not a bad virus, this may work.
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
Old August 24, 2009, 06:29 PM
Mr. Cipher's Avatar
I used this program once, UNLOCKER 1.8.7 BY CEDRICK 'NITCH' COLLOMB.
I know hijackthis also has a delete on reboot option, if you have the program.
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | Radeon HD 6870 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz |
BFG GTX 295 | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Old August 24, 2009, 07:10 PM
option 2
- restart
haha i was bored... so i downloaded things that arent illegal..... It wasnt a virus.. but i did use the UNLOCKER, thanks for the input man.
THANK YOU SOOOOOO MUCH!!!!!!!
Old August 24, 2009, 07:14 PM
haha yup... time to try another link....
Old August 24, 2009, 07:23 PM
element291's Avatar
hehe, yeah yeah
anyways, glad to see you got rid of it man!
Old August 24, 2009, 07:35 PM
"Quote This..."
Japanese tentacle rape porn no less.
Old August 25, 2009, 03:31 AM
Mr. Cipher's Avatar
Evil Dead? What?
Glad it worked
i7 Red
C2Q Blue
Old August 25, 2009, 07:48 AM
Safearus's Avatar
My question is, why would you know that?
Old August 25, 2009, 06:57 PM
omgwtf's Avatar
I had this problem but no virus or unwanted application found...
Memento mori
How do you permanelty delete these folders? appplejack O/S's, Drivers & General Software 1 July 15, 2009 04:07 AM
Cltrl Alt Delete Eagle Eye Off Topic 3 October 4, 2008 08:40 PM
How Do U Delete A Post??? God's Prototype Off Topic 1 January 19, 2008 11:55 PM
