<~----> Removing GRUB, Linux help please - Hardware Canucks
Old August 24, 2009, 03:31 PM
OJX's Avatar
OJX OJX is offline
Default Removing GRUB, Linux help please
So I want to remove Linux mint and GRUB and keep the Windows XP on my netbook. I found a solution to do it, but I need someone who understands linux to decipher this for me. I am a complete noob, so far I know that I have to log into terminal and do su - username in order to log in as root. The rest is lost on me.
You can do it under linx:
0. log in as a root
1. install lilo (if you do not have)
2. create a dummy lilo.conf
like this:
boot=/dev/hda
map=/boot/map
install=/boot/boot.b
prompt
timeout=50
default=dos
other=/dev/hda1
label=dos
install lilo to MBR
lilo -M /dev/sda -b /dev/shd
and uninstall
lilo -U -M /dev/sda /b /dev/sda
TimelineX 3820|13"|Core i3 350M|8GB DDR3|Intel X25 G2 80GB|BenQ G2420HD [1920x1080 2ms]
Old August 24, 2009, 03:47 PM
SugarJ's Avatar
If XP is your 1st partition, use MBRfix to overwrite the master boot record back to the windows version. Must be run from command prompt.
Download: Download
instructions: MBR Fix - Fix MBR problems
Now you can delete the linux partition, and extend your windows one.
Old August 27, 2009, 11:36 AM
OJX's Avatar
OJX OJX is offline
Download: Download
Hey man thats really useful, except I need some help
How do you run the program from CMD?
And then, do I just fix MBR?
Old August 27, 2009, 12:20 PM
SugarJ's Avatar
Start Windows XP.
Click Start. Click Run. Type cmd.
cd \locationofmbrfixfile (i.e. \downloads or wherever you put it)
mbrfix /drive 0 fixmbr (this is for xp, add /vista flag to redo vista MBR)
reboot.
Delete Linux partitions.
Old August 31, 2009, 11:39 AM
OJX's Avatar
OJX OJX is offline
Thanks a lot this worked :)
Much appreciated
Removing Parts from Your COmputer jcmaz Guides & How-to's 16 February 1, 2011 08:10 PM
GRUB error 22 JupiterTrooper O/S's, Drivers & General Software 16 May 1, 2009 03:57 PM
Removing GX2 shroud k3nnny Video Cards 0 February 5, 2009 10:54 PM
Got any ideas on removing stickers and their left behinds? Cadence Guides & How-to's 11 November 19, 2008 09:59 PM
Removing the IHS, Opty 170 kirk_d CPU's and Motherboards 12 November 2, 2008 03:52 PM
