Old August 23, 2009, 11:46 PM
Default How to save your "Favourites"
I'm planning to upgrade my OS to windows 7 when it's out.
Is there any way of transferring my favourites from my firefox to my new firefox?
CPU:Intel i5 6600k - Corsair H110
GPU:EVGA GTX980Ti FTW Edition
HDD:250GB Samsung Evo 850 SSD, 3TB WD Black
MOBO:Asus Z-170 Deluxe
RAM:G.Skill Ripjaws V F4 2800mhz 16GB
PSU:Silverstone 950W
CASE:Silvertstone TJ07
Keyboard:Logitech G15 V2
Mouse:Razer DeathAdder
Case Cooling:2x92mm exhaust,2x120mm exhaust, 2x120mm Ultra Kaze(3000RPM)intake.
Running:Win7 64-bit Ultimate
Old August 24, 2009, 04:35 AM
Safearus's Avatar
Yes:
Ctrl+Shift+B (Or click "Bookmarks -> Organize Bookmarks")
You should see a button that says: "Import and Backup"
Backup your favorites, in whatever form you want. Import once you update, just make sure to save the file(s) somewhere.
Old August 24, 2009, 08:46 AM
thanks!
Old August 24, 2009, 09:04 AM
chrisk's Avatar
Folding Captain
I back up my Firefox bookmarks, themes, add-on, and settings by backing up my entire profile. Directions here: Profiles
Step 1: Vista: Copy C:users\username\appdata\roaming\Mozilla\Firefox\P rofiles\profilefoldername(randon letters).default , or XP:C:\Documents and Settings\username\Application Data\Mozilla\Firefox\Profiles\randomletters.defaul t
Copy the above directory to your backup location.
Step 2: On your new computer, paste the ".default" folder back into the same directory as above. If you see another ".default" folder in there, rename the ".default" to something like ".defaultold" or whatever you want.
Step 3: In the Firefox folder (Vista C:users\username\appdata\roaming\Mozilla\Firefox\ , or XP C:\Documents and Settings\username\Application Data\Mozilla\Firefox\ ), you will see a file called "profile.ini". Open it with notepad, and rename the "Path=Profiles/randonletters.default" line to the same name as your old profile.
Hope this does not sound tricky. You are basically just copying your whole firefox folder to your new setup, and changing the 'profile.ini" file to point to your old directory. That way, you get your firefox just the way you had it, extensions, settings, and all. If you look around, there are probably lots of backup extensions too.
Fold for team #54196
Old August 24, 2009, 09:11 AM
Arinoth's Avatar
Safearus' way is a lot easier and straight forward chris, lol (i did it myself with my girlfriend's computer 2 weeks ago and its a few clicks, not directory hunting likes yours)
Here I am: here I remain
Old August 24, 2009, 09:17 AM
chrisk's Avatar
Folding Captain
Does it just get your bookmarks, or all your Firefox stuff? If all you want are bookmarks, then yes, the first method is better.
Me, I like to keep my extensions, settings, themes and figured it would be nice to let the OP know that option exixts...if the first method works for all those too then I would use that, but I only wanted to let the OP know you can keep your bookmarks, settings, themes, add-ons, etc....
Old August 24, 2009, 09:29 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Mozbackup is another good way to back everything up. ;)
MozBackup - Backup tool for Firefox and Thunderbird
Old August 24, 2009, 10:02 AM
gingerbee's Avatar
wow way to make something as simple as backups hard guys come on ( all software comes with it's own way to do backups)
KISS= keep it simple stupid and this is JMO
Old August 24, 2009, 10:14 AM
lowfat's Avatar
Just copy the entire user\AppData folder. That way you save your settings for damn near every application.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old August 24, 2009, 10:19 AM
chrisk's Avatar
Folding Captain
I guess copying and pasting a folder is hard then.
As I said, if all you want are bookmarks then the first method is best. All I did was offer a method I have used to copy all of my FF stuff as well. If the OP finds locating a folder and copying it difficult then he does not have to do it lol.
BTW Method works almost exactly the same for Thunderbird email client as well. You get all your emails, contacts, server settings, etc.
[WTB] 1/2" "T" fitting for watercooling Toronto122 Buy/Sell & Trade 5 February 26, 2009 10:38 AM
Fake "Do Not Call" cell phone registry hits the streets sswilson Press Releases & Tech News 0 November 26, 2008 09:21 PM
"Girly" 2.5" IDE Enclosures encorp Storage 13 July 14, 2008 09:19 AM
