Old August 20, 2009, 02:27 AM
trodas's Avatar
Question Macromedia Flash registry keys non deletable?
Hello, friends.
On friend machine I made the mistake of installing the Adobe Macromedia Flash, instead of just depacking the installer and copy over the relevant files in Firefox plugins. As result, there are several non-deletable (regeditor refuse to delete them, CCleaner did not delete them as well) registry entries:
Both from Flash 9b and 10b versions as you can see in the image. Since regedit refuse the delete the keys AND CCleaner also refuse to delete them, I tried even the Registry Booster, yet this one did not even list them as error. If that is significant, I don't know. I just want them to "go away" and don't know how.
Thinking about Windows PE boot, but not sure if that is safe and if that will allow well me to manipulate with registry... Is not there any other way? There is NOTHING from the flash files in Windows directory at all. All are removed/deleted. I stick with the
flashplayer.xpt
NPSWF32.dll
NPSWF32_FlashUtil.exe
files extracted from the install and put in Firefox / Plugins, so I will not ever install that crap again. Never did on my machine and no problemo. But in case someone do, is there a known way to fix this? Using the Adobe utility to clean up is NOT the way to do...
Also installing new version did not seems to fix a thing.
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
Old August 21, 2009, 10:37 AM
Gellidius's Avatar
TuneUp Utilities has a registry editor
Jacques
Ego cogito, ergo deus non est.
Old August 29, 2009, 12:37 PM
trodas's Avatar
Talking
At first I tried this suggestion: FlashUtil9b.exe -uninstallUnlock
Well, first at all I tried the FlashUtil from 9.0b and yea! Much better, only two errors now:
So far, so good. However using the Flash 10 utility by the same way ( -uninstallUnlock ) I get this error message:
Something about impossibility of finding a "GetSystemWow64DirectoryA" is not possible in the kernel32.dll ... hmmm.
So, I tried the other options of the FlashUtil9:
-unregisterBroker
-uninstallDelete
-uninstallControlPath
-uninstallBrokerPath
-uninstallSafeVersions
...but with bad result, as the number of errors only increased by one :(
Next try - I try unlocking these registry keys using the regedt32 ;) Let's hope for the best :)
And yes - unlocking these registry keys using the regedt32 worked jest great. They all had passed some properties that make then uneditable and so on, so removing this AND setting the permissions to "allow" for everyone and then deleting them fixed the annoying problem
Old August 30, 2009, 07:31 AM
Resplendent Registry has a free version
I used it get out zone alarm leftovers, that regedit and other apps wouldn't touch
Resplendence Software - Registrar Registry Manager
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel SSD
Win 10 Pro x64
Free Technet: Were the keys ever blacklisted? Nodscene O/S's, Drivers & General Software 4 August 6, 2009 05:01 AM
keys for Parabellum beta mo' power Gaming 9 August 2, 2009 02:55 PM
Problem with volume control and media keys TimTheEnchanter Audio 5 July 27, 2009 03:07 PM
registry disabled by admin MrFoxx O/S's, Drivers & General Software 7 July 8, 2009 06:32 AM
