Old August 6, 2009, 10:37 PM
ToXic's Avatar
Default vista issue
so im reinstalling after assembling my new gaming rig, and i need to put vista x64 on there but all i have is basic x32, and a ultimate upgrade witch is 32 and 64. is their any way i can download x64 but use my x32 licence then use my ultimate upgrade? I really dont feel like buying a new version of vista basic.
Some kind of pathetic Apple convert
17" Macbook Pro (early 2011 model)
2.2Ghz i7-2720QM | 8GB Corsair DDR3 1333Mhz | 750gb Toshiba HDD | ATI 6750M 1GB
Old August 6, 2009, 10:39 PM
Your question is really confusing to me.
So you have Vista Basic x32
And a Vista Ultimate Upgrade which contains x32/x64
So why not simply install Basic x32 then upgrade to x64 Ultimate?
Old August 6, 2009, 10:43 PM
ToXic's Avatar
i can switch bit types after already having a x32 system installed?
because i must install x32 vista basic first, then run the x64 ultimate pack, im wondering if it will tell me im on a x32 system because of the basic x32.
Old August 6, 2009, 11:53 PM
ToXic's Avatar
anyone?
Old August 7, 2009, 08:18 AM
grinder's Avatar
use the ultimate x64 media with your vista basic key and VIOLA you have 64 bit Vista Basic.
The cd-key you use is not locked as being a 64bit or 32 bit edition, they work either way.
and no... you cant upgrade your vista basic 32 to vista ultimate 64. when you change... um... BITS? you need to do a custom install.
Old August 7, 2009, 09:55 AM
martin_metal_88's Avatar
+1 grinder, Microsoft will tell you that it's impossible but it is. It work really well. You can also use any disk of 64 bit, basic home prem buisness or ultimate should work. Thx to windows to add this awsome way of doing inv ista, and remove it for win 7 according to anadtech...dummy MS, but love them:)
Ask for more.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old August 7, 2009, 12:27 PM
ToXic's Avatar
i dont have a 64 bit disk exept the windows anytime upgrade to ultimate witch of coarse is not a bootable disk. So is their any way i can do this without buying a new os?
Old August 8, 2009, 08:23 PM
grinder's Avatar
you could risk a torrent i suppose. Tho i would recommend trying a borrow a friends or family members 64 bit installation media if they have one available.
Old August 8, 2009, 08:41 PM
ToXic's Avatar
see i have a dell version, but of coarse that wont work.
Old August 8, 2009, 09:21 PM
How about ordering a 64-bit DVD? Not sure if it will like any of your product keys (it didn't like mine) Windows Vista Alternate Media
Is the Dell disk you're talking about the "operating system" disk or a "system restore disk"? If it says it just contains the OS, then you may be able to activate it with another product key, although Dell logos will be all over the place. I'll try my Dell Vista Business disk on a non-Dell and see what happens...
Issue :[ DavidDemise Troubleshooting 56 March 22, 2009 07:04 AM
Vista Services issue? 3.0charlie O/S's, Drivers & General Software 17 March 3, 2009 04:45 PM
Weird Vista Issue lcdguy Troubleshooting 19 October 10, 2008 05:17 AM
Vista --> XP Network Issue Thund3rball Networking 6 March 5, 2008 05:14 PM
Harddrive issue in Vista Ultimate FrankyG Storage 1 January 10, 2008 05:42 AM
