Old July 1, 2009, 09:25 PM
ebdoradz's Avatar
Default best freeware for my system
im reinstalling my both rig at home and i want to get the best freeware available
im currently using
Comodo Firewall Pro
Avast!
then for system clean up
Ccleaner
Spybot search and destroy
SuperAntispyware
Defragler
Comodo now offer a system cleaner and i havent give it a try yet
anyone have great freeware that can do the job right without having to install 12 diff programs??
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 5112mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
ABIT KT7A-RAID / AMD Athlon XP 1800+ @ stock/ 2*256mb PC133/ Geforce 4 mx440 / 250W PSU / Maxtor 20GB
Old July 1, 2009, 11:07 PM
JD JD is offline
Drop Spybot and use MalwareBytes Anti-Malware.
Could go with Jkdefrag or Auslogics instead as well. Don't think Defraggler is one of the top-rated ones.
Software firewall is useless IMO assuming you have a router. One could argue all security software is useless if you just browse safely since I don't have any AV, software firewall or any anti-spyware/malware programs installed.
There's no magical all-in-one program though so you'll have to install a bunch of things no matter what.
Old July 2, 2009, 09:34 AM
Thund3rball's Avatar
Battlefield Heroes
FEAR Combat
Quake Live
Far Cry (gamershell.com)
Red Alert
I understand what you are saying so correct me if I am wrong. But I thought a router will only stop inbound nasties. If something does infect your system and say it wants to email itself to all your contacts, your router won't do jack. So in that case a software FW will be the only thing to stop it.
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Old July 2, 2009, 09:52 AM
thenewguy001's Avatar
^ yep. hardware firewall only stops incoming probes. software firewall actually tells you your system is compromised if it's logging unsolicited transmissions.
Core 2 Quad 6600 @ 2.8 GHz
2 x 2GB G.Skill PC2-8500 @ DDR2-1040 MHz
XFX HD5770
Gigabyte GA-P35-DS3L
Antec Truepower Trio 650W
Scythe Ninja Rev B w/ MX-2
CM690 w/ 1-80mm, 6-120mm fans.
Old July 2, 2009, 10:10 AM
Bonami's Avatar
You don't think Zonealarm is any good? So what's protecting your O/S?
Old July 2, 2009, 10:28 AM
Shadowmeph's Avatar
I agree with pretty much everything said. this also depends allot on which OS you are using there is one program that I use on my win xp OS that is great and that is returnil the free version works great the only thing is that if you install anything with returnil on and you reboot well it won't be there so to install anything you have to turn off returnil. this is why I use portable applications on a separate partition ( I got the idea when using linux). also use a decent hosts file which also protects pretty good the hosts file is located C:\WINDOWS\system32\drivers\etc\hosts . this is all I can think of off the top of my head
Work in Progress
Folder : Parts so far
;ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6128 CPUs 2x NH-U9DO A3.inside a old hacked up case no side panels and a laptop harddrive , almost perfect for those cold winter months
BackOrdered
Parts needed;
A better case
Old July 2, 2009, 09:19 PM
JD JD is offline
I don't know about you guys but I never get spyware/malware/viruses. You people must be going to some crazy sites
And yes I have installed various programs and scanned from time to time only to turn up clean. Thus why I don't bother to have any security software running.
The odd time I want to go to some random site for whatever reason, I just fire up a XP virtual machine and go to it there.
If I HAD to run one, it would be Comodo for firewall. I use NOD32 as my anti-virus (assuming I bother to install it)
Old July 23, 2009, 06:45 PM
When you start backing up media, Get Media Player Home Cinema to do playback. http://mpc-hc.sourceforge.net/
Shareware/Freeware gems Shadowed O/S's, Drivers & General Software 77 May 7, 2011 12:56 AM
Synchronization Freeware misterlarry O/S's, Drivers & General Software 1 May 20, 2009 07:06 PM
HTPC freeware suggestions Mr. Gruntsworthy O/S's, Drivers & General Software 7 May 7, 2009 11:54 AM
New System! :) Kandorf Troubleshooting 2 October 3, 2007 04:24 PM
I need some help with a new system SirenOfDarkness Troubleshooting 0 September 7, 2007 08:51 PM
