-   O/S's, Drivers & General Software (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/)
-   -   Firefox 3.5 - The web is fast again. (http://www.hardwarecanucks.com/forum/o-ss-drivers-general-software/19437-firefox-3-5-web-fast-again.html)
Thund3rball June 30, 2009 09:51 AM
Well I just installed FF 3.5 on my Mac and hallelujah she is a speedy browser! I know my biggest complaint with FF3 was it's speed so I am a happy camper. FF 3.5 is also sporting some new features that you can read up on at Mozilla.
I will upgrade my PC at home tonight... I hope the performance increase is just as noticeable there.
Arinoth June 30, 2009 09:59 AM
I am doing that as we speak and will give feedback on its performance after i install it and after i finish watching weeds
FiXT June 30, 2009 10:15 AM
Hhhmmm - Well I like it a lot better than FF3.0
We will see how it does with the memory leaking issue.
For now though, I'm sticking with my chrome.
thenewguy001 June 30, 2009 10:19 AM
Argh. One of my favorite addons is incompatible. I hope there is an update soon.
Arinoth June 30, 2009 10:27 AM
Well its installed and i don't notice a difference really on my rig. Luckily the only add-on i use works so hurray and hopefully yours gets patched soon thenewguy001
chrisk June 30, 2009 12:27 PM
Holy crap most of my add-ons were not compatible, as was my theme. Slimsearch not working is strange, as it has never had a compatibility issue when upgrading in the past.
DarKStar June 30, 2009 12:29 PM
Huh ? Nobody using Internet Explorer anymore ? ;-P
Eldonko June 30, 2009 12:40 PM
3.5 is great
chrisk June 30, 2009 12:41 PM
Slimsearch (which has been around for years on FF) is like the Accelerators in IE8. I use Slimsearch extensively. If it is not updated soon I'll head over to IE8 a little more often. I prefer to use an updated browser.
Other than the various extension issues, no real problems so far. I would wait a few more days or even a week or two before updating if you have many extensions or themes you like. Perhaps I can see if my extensions will run anyways...
chrisk June 30, 2009 12:50 PM
Got my Slimsearch add-on to install using "Nightly Tester Tools" add-on. Allows you to override incompatibility issues. Seems to be working fine now and FF 3.5 seems OK too with Slimsearch enabled.
