Old June 19, 2009, 05:36 PM
Cranky's Avatar
Default Calibration software
Does anyone know of any good free LCD TV software, and or image calibration tools?
thanks
Asus P5K Deluxe / Intel Core2Quad Q9550@8x425@3400mhz(1.225v) / Arctic Cooling Freezer 7 Pro / 4Gigs DDR2 1066mhz(5-5-5-15) Corsair Dominator / Diamond HD4870x2 / Asus Xonar / WD Raptor 74gb / Hitachi 160GB / Antec Quattro 850w / Logitech Z-680 5.1 / Dell Ultrasharp 24" / 2 LG Optical Drives / Vista Ultimate 32bit / A tower that's been drilled, cut, and bent to fit all of my fans
Old June 19, 2009, 07:27 PM
JD JD is offline
Similar thread here: Color Calibration
Though TVs are much harder to do properly. You basically have to hire somebody in with all the equipment to do it. It's apparently well worth the money though.
You can do the cheap DIY way and just adjust settings by eye or get one of those calibration DVDs (THX-certified DVDs apparently have one on them), but you need some glasses from THX to do one of the tests. They're like those 3D glasses and fairly cheap.
Old June 23, 2009, 03:37 PM
Default not free
I've tried a few times to find a free solution for lcd adjustment but none exist.
Old June 23, 2009, 04:17 PM
Cranky's Avatar
Thanks
Old June 23, 2009, 07:48 PM
JD JD is offline
Forgot to mention, Google your TV model and see if anybody has posted settings for it. Can try here to start: Tweak My TV to get the most accurate calibration settings for my HDTV, only at TweakTV.com*-*TweakTV
I just do it by what I like though, it's not like a TV has to be 100% accurate since you aren't doing graphic editing on it. Should just make it how you like.
Old June 23, 2009, 11:12 PM
Thund3rball's Avatar
I used the THX calibrator avaiulable on the Star Wars DVDs on my TV. Of course it's all by eye and hardly scientific, but it's better than nothing.
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Old June 24, 2009, 07:15 AM
Cranky's Avatar
Thanks for all of your input, I guess I'll try my "old" eyes and see how it works out for me.
Doh! Thanks Thund3rball, I didn't know that the Starwars discs had that feature. I tried it and it made a difference.
Color Calibration crispex Display Units 16 July 17, 2014 10:38 AM
Gigabyte Motherboards & Load-Line Calibration... somecanadianguy Overclocking, Tweaking and Benchmarking 27 May 20, 2009 05:36 PM
Eq Software? aviduser Audio 2 May 6, 2009 10:55 AM
Back up software?? Cowinacape O/S's, Drivers & General Software 7 December 31, 2008 06:00 PM
Software WolfBane Networking 11 August 1, 2008 12:28 PM
