Old June 19, 2009, 06:35 AM
Cranky's Avatar
Default Spybot Search and Destroy problem
I can't seem to completely immunize my Internet Explorer under 32/64bit, "domains" and "secure domains" What do I have to do to solve this problem?
Thanks
Asus P5K Deluxe / Intel Core2Quad Q9550@8x425@3400mhz(1.225v) / Arctic Cooling Freezer 7 Pro / 4Gigs DDR2 1066mhz(5-5-5-15) Corsair Dominator / Diamond HD4870x2 / Asus Xonar / WD Raptor 74gb / Hitachi 160GB / Antec Quattro 850w / Logitech Z-680 5.1 / Dell Ultrasharp 24" / 2 LG Optical Drives / Vista Ultimate 32bit / A tower that's been drilled, cut, and bent to fit all of my fans
Old June 19, 2009, 11:13 AM
bojangles's Avatar
I used it and have grown to hate it. Immunizing is kinda stupid if you ask me. A firewall will do just fine. Just run the cleaner when you get the chance. There are also way better alternatives out there too.
Old June 23, 2009, 03:39 PM
Are you immunizing with IE closed? Run malwarebytes and spywareblaster as well, see if that helps, browsers closed.
Old June 23, 2009, 04:17 PM
Cranky's Avatar
Yes, I am running with it closed. And the problem I'm experiencing isn't due to infection. There is a procedure I have to follow to do a complete immunization while running Vista but I can't remember what it is. I was hoping that someone know what is is offhand.
Old June 23, 2009, 04:55 PM
People still use Spybot?
Superantispyware and Malwarebytes is far superior.
How to use google to search? Mark O/S's, Drivers & General Software 8 May 29, 2009 01:00 PM
Search function Eldonko Suggestions & Feedback 3 May 25, 2008 07:09 PM
A new search engine? 3.0charlie Off Topic 10 April 1, 2008 10:49 AM
In search of a silent solution CMetaphor Water Cooling 13 February 13, 2008 08:51 PM
Price search for BC only donkey44 Troubleshooting 0 January 30, 2007 03:06 PM
