Old June 15, 2009, 06:56 PM
Default Catalyst 9.6 released
ATI Catalyst 9.6 drivers released - Neoseeker News Article
New catalyst drivers for ati cards released today. Gonna install them and see how they run on win7 x64
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
Old June 15, 2009, 07:29 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
I wish I could get excited about this....
Old June 15, 2009, 07:51 PM
gingerbee's Avatar
no kidding
Old June 15, 2009, 08:15 PM
martin_metal_88's Avatar
Any one have found a list of what the new driver fix? For now I see the HDMI sound driver wich are new and working realy smoothy ( i like )but for the rest nothing...was it needed to make a new bundle driver instead of an update?
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
ok this is pissing me off now lol, it says driver inf file not found when i try to install it. The only info i find on this is for a leaked version that says you have to dl a "patch" for windows 7, yet the files it says you replace with the patch files arent even there.
Case: HAF 932
Mouse: Logitech G9
Old June 15, 2009, 09:39 PM
SKYMTL's Avatar
Knowing ATI's drivers, it will fix some things and break others. I was using a dual HD 4870X2 setup for some upcoming PSU reviews. 9.2 to 9.4 worked fine. 9.5 wouldn't allow itself to be installed. That may be fixed now but I am not willing to check.
Basically, I am done with ATI's drivers in our GPU reviews as well. We will update the ATI drivers in the reviews when Nvidia releases a new driver unless ATI makes some claims of performance increases in games we test. Simple as that. This whole mentality of releasing monthly driver updates which do nothing but fix problems created by the last driver release is getting really, really old now.
Old June 15, 2009, 10:02 PM
JD JD is offline
Installed fine over my previous 9.5 install (or maybe it was the Win7 WHQL set). Running the RC x64. No issues to speak of.
Old June 16, 2009, 08:33 AM
ahh i decided to uninstall and run driver sweeper for the first time for a clean install, go me. Something tells me the drivers for win7 are still the same and its just ccc thats updated.
Case: HAF 932
Mouse: Logitech G9
Old June 16, 2009, 03:59 PM
Oversized Rooster's Avatar
I hope they fixed the random crashing in games and/or videos that 9.5 created...
Main: Intel 2600K @ 4.8GHz | Gigabyte P67A-UD7-B3 | 16GB Corsair DDR3-2000 | 2 x 240GB Corsair Force 3 in RAID1 | 2 x 4TB Hitachi 7K4000 | 3 x 2TB WD Caviar Black | 3WARE 9650SE | Antec 1200 | Seasonic XP-860 Platinum | 2GB GTX 670 | 2 x 27" Asus VE278Q | Auzentech Prelude | Win7 Pro 64-bit
Old June 17, 2009, 09:22 AM
TimTheEnchanter's Avatar
9.6 mostly improves crossfire performance, if i understood well.
ATI Catalyst 8.10 Drivers Released MAC Press Releases & Tech News 6 October 16, 2008 09:14 PM
ATI Catalyst suite 8.3 released Babrbarossa Video Cards 10 March 9, 2008 10:24 AM
ATI Catalyst 7.12 Driver Released SKYMTL Press Releases & Tech News 0 December 20, 2007 06:34 PM
ATI Catalyst 7.11 Drivers Released SKYMTL Video Cards 1 November 21, 2007 05:22 PM
