Partition problem...
Really big problem guys.
I had vista everything was working great but then I decided to install ubuntu (bad decision). I formated C:\ maked a 80GB partition where i reinstalled vista and on the other 40gig i was planning to put ubuntu. I had another 180GB partition ntfs with stuff on it.
So, I try to put ubuntu, then i suddenly change my mind. I resize the 2 partitions the 80 and the 40gig and put xp on it. I enter windows explorer, and what do I see? no D: partition. I install Partition Magic, only one NTFS partition. I put the vista bootable cd, the same. I put the ubuntu bootable cd, at the partition thing it appears 2 ntfs drives. D: couldn't bee ext2 or ext3...i don't know what to do...
__________________ Memento mori |
