Old June 7, 2009, 04:19 AM
Default Win 7 and new system Question
Hello,
I am going to be building a system within the next month and I plan to install Windows 7 RC on it. However, when it will be time to buy Win 7 later on, wouldn't it cost me more because I'd have to buy the retail version or am I mistaken ?
Old June 7, 2009, 04:48 AM
gingerbee's Avatar
retail vs the upgrade path. i always buy new oem disks jmo ( and yes i believe the upgrade is cheaper it's been a while )
Old June 7, 2009, 09:36 AM
JD JD is offline
I believe you can only upgrade from Vista and well I hate upgrading OSes. Leaves too much crap behind and typically causes issues.
Just buy the OEM version of Windows 7 when it comes out. It'll do the trick.
Old June 7, 2009, 12:00 PM
My question was actually: When buying an oem version of an o/s, dont you need to buy some other parts with it ?
Old June 7, 2009, 07:14 PM
JD JD is offline
I've bought OEM XP without buying a full PC. I guess it really depends on where you buy it from.
Old June 7, 2009, 08:38 PM
Arinoth's Avatar
I bought oem copy of Vista from my school without buying parts so i'd assume most places should still do it
Here I am: here I remain
Old June 7, 2009, 08:43 PM
bojangles's Avatar
If you're in a computer/software/electrical program, see if your school or IT dept. has a license handy. Sometimes they're more than willing to hand out a free key or two. That's what I did. Then I got E-Academy MSDN.
Old June 8, 2009, 12:16 PM
JD JD is offline
I'm on that too =)
But it's only Vista Business up there so I imagine the Windows 7 version I'll get will be Professional. Still, nothing wrong with free legit software.
2 problem in win 7? upcoast604 O/S's, Drivers & General Software 12 March 25, 2009 04:18 PM
Win 7 64 and games? upcoast604 O/S's, Drivers & General Software 3 March 6, 2009 10:19 PM
Steelers win!!!!! kruzn4evr Off Topic 13 February 2, 2009 03:50 PM
Stupid HWC ranking system question :D shayan288 Off Topic 2 January 8, 2009 04:28 PM
Win With AMD!!! werty316 Off Topic 20 March 11, 2008 04:41 PM
