This is pathetic. I did a small windows 7 update, pressed restart and went away. Next time i saw my computer, i saw the horrible message "a disk error occured"
Happens on startup with my HDD on dual boot win7/xp.
What can i do, i have never had such a problem.
I have only two hdds, both used.
I'll try to install Win7 on my flash drive and take back my data.
Hmmmm, corrupt boot sector? Have you tried running the Win7 install disk and the trying a "fix startup" option (might not be what its called, id have to check for the exact wording)?
Whats with the usb key? Try getting the Windows 7 installation disk, put it in the system and boot off of it. Once its done loading, look for a repair option then find the "fix startup" or whatever its called and do that. hehe
Ok, dvd loaded, went for the repair option, loaded the system recovery options (took a minute), found my W7 OS, chose the "use recovery tools that can help fix problems starting windows", clicked on "startup repair", searched for problems, said it could not detect a problem.
3 choices now :
-view diagnostic and repair details
-view advanced options for sstem recovery and support (this one i guess)
-finish (umm i guess not...)
try the advanced tools and see if you can run "fixmbr" and "fixboot", im not certain about these tools with Windows 7 though since I haven't used it that much yet.... at least not enough to corrupt it . hehe.
clicking this brings me back to the menu : startup repair, system restore, system mage recovery, windows memory diagnostic, command prompt... how can i try running fixboot? command prompt? how?
