Old June 2, 2009, 10:41 AM
biff's Avatar
Default Need to reinstall WMP 11
I need to reinstall WMP 11. I've read up on how to do this but unfortunately the hidden directory is missing, that being "C:\WINDOWS\$NtUninstallwmp11$\spuninst\spuninst.e xe". Apparently some driver cleaners will wipe out this directory which seems to be what happened to me.
So where do I do now?
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old June 2, 2009, 11:00 AM
3.0charlie's Avatar
I didn't know you could remove WMP11... how did you do this?
I'd suggest you d/l from Microsoft and re-install?
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
Old June 2, 2009, 12:35 PM
biff's Avatar
Well I haven't removed it yet but apparently the file I quoted above is the way to do it. BUT a driver cleaner I have used along the way has wiped out that uninstall info (apparently not so uncommon of a problem). I tried DL'ing it from MS but it wont let me install... but the only version of WMP11 I could find at MS was for XP and I'm using Vista.
I'm almost to the point of formatting the drive and doing a fresh install.... for all the time I've wasted looking for a fix I probably could have already had the fresh install done and setup.
Asus P5Q-PRO
EVGA GTX 280 (SC?)
Old June 2, 2009, 12:43 PM
3.0charlie's Avatar
I've read that you may need to re-install the OS, but here's the WMP 11 for Vista link: Windows Media Player 11 for Windows Vista
edit: I think from reading MS's site that you have no choice but to re-install the OS...
Old June 2, 2009, 12:56 PM
biff's Avatar
Yeah that's the same download I tried to use... if you notice on the download button it says "...for Windows XP". I guess they use the same version.
I think I'll just do the OS reinstall. It's only for my HTPC so I have next to no setup to do after anyway, just iMON and TMT I think. Thanks.
Asus P5Q-PRO
EVGA GTX 280 (SC?)
Old June 2, 2009, 01:13 PM
Why bother with WMP 11?
VLC + Media Player + CCP for all video playback
Winamp for any audio.
Old June 2, 2009, 02:32 PM
biff's Avatar
Never heard of VLC, but I've already bought TMT anyway. Besides I see no mention that it can play bluerays. I also can't find anything that says that winamp will integrate into VMC. I'm not a big proponent of either but WMP11 works perfectly (when you don't bugger it up with other 3rd party software) and it's setup and ready to go out of the box. I wouldn't mind using third party software to handle music so if it ever craps out I can easily do a re'n're... as long as it's as seamless as WMP11 is in VMC.
Asus P5Q-PRO
EVGA GTX 280 (SC?)
Old June 2, 2009, 02:41 PM
Your using acronyms I have no clue about.
TMT? VMC?
Old June 2, 2009, 04:07 PM
no idea what TMT is, but VMC is vista media center. for htpc.
Old June 2, 2009, 04:25 PM
khelben1979's Avatar
Never heard of VLC
I agree on VLC (check the wiki link).
new HDD noise on secondary drive after Vista reinstall? donimo Storage 6 December 13, 2008 11:57 PM
Reinstall XP - 2nd HD issues Matty D Storage 22 November 27, 2008 10:58 AM
Audio and Video skipping during playback WMP and Nero Showtime Eagle Eye Troubleshooting 3 September 17, 2008 02:39 PM
Trying to uninstall COD4 and.....reinstall a new copy.. Canadianguy Gaming 3 March 19, 2008 05:59 PM
Reinstall over due, bittorrent files still downloading Mysteryous O/S's, Drivers & General Software 2 November 7, 2007 03:54 PM
