Old June 2, 2009, 03:36 PM
Well personally I'm not a huge fan of Media Center anyways.
I've much preferred XBMC Media Center for Mac OS X, Windows and Linux over Media Center any day of the week.
biff's Avatar
Originally Posted by enaberif View Post
Your using acronyms I have no clue about.
TMT? VMC?
Sorry, VMC is Vista Media Center and TMT is Total Media Theater by Arcsoft. Ive tried a freeware media center once, IIRC it was MediaPortal. I'm sure it's (or anything else) is more versatile than VMC but I spent a couple days with it and didn't get too far in getting everything working properly and TBH I don't have the time these days. Maybe XBMC is different... maybe someday when I get some extra time I'll play with it.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old June 2, 2009, 03:43 PM
Silvgearx's Avatar
MPC-HC + K-lite codec for all your needs
As for VLC, its a decent player if you don't want to install codecs but i has its problems
For blu-ray i think its better to use something like PowerDVD, it uses less resource and make those Ati work for your decoding
And WMP 11? i don't even have it configure
for the WMP 11, can't you just roll back ? or pop in the vista DVD and repair?
Old June 2, 2009, 06:29 PM
biff's Avatar
Rollbacks only go back a week and a half... someday I'll get on figuring out how (if) vista (and XP too) can save rollback points automatically. It's funny it's one of those things you don't think of until AFTER you need it.
And AFAIK Vista doesn't have the same add/remove/repair windows components from the DVD like 2k & XP did. Maybe the full version does but I have the upgrade version.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old June 2, 2009, 07:07 PM
TopDogZero's Avatar
+1. Works really good with ATI cards for BlueRay and DVD's, VMC is OK for TV tuner and plays nicely with ATI avivo persets if you to use them. GOM, VLC or Media Player Classic with ffdshow for everything else.
new HDD noise on secondary drive after Vista reinstall? donimo Storage 6 December 13, 2008 11:57 PM
Reinstall XP - 2nd HD issues Matty D Storage 22 November 27, 2008 10:58 AM
Audio and Video skipping during playback WMP and Nero Showtime Eagle Eye Troubleshooting 3 September 17, 2008 01:39 PM
Trying to uninstall COD4 and.....reinstall a new copy.. Canadianguy Gaming 3 March 19, 2008 04:59 PM
Reinstall over due, bittorrent files still downloading Mysteryous O/S's, Drivers & General Software 2 November 7, 2007 03:54 PM
