Old July 8, 2007, 09:28 AM
3.0charlie's Avatar
Finally got it to POST, and Memtest is stable. First stick is dead, one gazillion errors on forced test #6. Running test #6 ATM on second stick. Thanks guys, I'll keep you posted.
John
Second stick is also dead. Damn. Could it be that the memory controller is dead, instead of the sticks? Is there a way to test this?
Old July 8, 2007, 09:34 AM
CMetaphor's Avatar
Quadfather
Not really a way to test it. Mem controller is on the mobo for intel boards anyways. Do you have another motherboard to test the ram with? Im starting to think its th XFX mobo thats your problem-maker.
sswilson's Avatar
Are there any "enhanced" memory settings in bios????
If both sticks are behaving the same way my first inclination would be towards a setting that's just out of whack (set too low).
Old July 8, 2007, 09:37 AM
CMetaphor's Avatar
Quadfather
I seriously doubt that ram would misbehave when being set "too low". I still think your motherboard is the culprit here, as i have never seen two sticks of defective memory out of the box (1 maybe, but not 2 with the Same Problem)
Old July 8, 2007, 09:39 AM
sswilson's Avatar
I'm thinking tRFC (Refresh Cycle Time) is set too low, but that would normally affect the ability to boot rather than mem errors.
Old July 8, 2007, 09:41 AM
CMetaphor's Avatar
Quadfather
That could be possible actually. But thats still a motherboard problem more than the ram. My only point was i think the motherboard is not liking the ram at all - which is why i suggested testing the ram in a different motherboard.
Old July 8, 2007, 10:20 AM
3.0charlie's Avatar
Everything RAM-wise is set to default - except voltage. I will try the tRFC later tonight, and I do still have the ECS mobo. I will try this one too. I'm really leaning towards a mobo problem too, since the ECS mobo (though no oc) was stable and actually folding too.
I'll let you guys no more tonight.
John
AMD is exploring options Shadowed Press Releases & Tech News 5 April 21, 2007 12:48 PM
