Old May 15, 2009, 09:14 PM
Default Conversion Program
Does anyone know of a decent program to convert .avi files to .mp4 for an IPOD Touch? Freeware preferable but any suggestions are welcome
Thanks in advance,
IM THE DUDE, PLAYING A DUDE, DISGUISED AS ANOTHER DUDE.
Old May 15, 2009, 09:55 PM
Realityshift's Avatar
I thought you could do that from Itunes?
If not this should work, its for the PSP but same idea, they both use MP4 formats.
PSP Video 9 - Free PSP Video Converter
Ive used it before, always worked well for me.
The Builders Hammer
Old May 15, 2009, 10:21 PM
chrisk's Avatar
Folding Captain
I use Mediacoder for many conversions; MediaCoder - more than a universal audio/video transcoder
I have not used mp4, but its supported.
Fold for team #54196
Old May 15, 2009, 10:38 PM
JD JD is offline
I used to but I don't know, I just can never seem to get the results that I want from it. Seems glitchy a lot of the time.
I use StaxRip now instead, which uses all the "standard" programs like VirtualDubMod, AviSynth etc. Just gives you a simple to use GUI and does all the steps between programs for you. It has a built-in PSP profile, but you could modify that to your needs for the iPod.
Old May 16, 2009, 05:27 AM
gingerbee's Avatar
nero recode and the gordian knot package can do everthing under the sun. that what i am using now
Old May 16, 2009, 06:56 PM
TopDogZero's Avatar
+1 for MediaCoder
Ps3 video conversion Jonwall O/S's, Drivers & General Software 6 March 21, 2009 11:01 AM
MPEG-2 conversion Mr. Gruntsworthy O/S's, Drivers & General Software 5 February 14, 2009 08:09 PM
i need help finding a program EaGle1337 Off Topic 0 January 26, 2009 06:37 PM
program Rapid-X O/S's, Drivers & General Software 8 September 3, 2007 06:13 PM
CS:S ti normal program Long John Silver Gaming 5 June 21, 2007 07:32 PM
