Old May 13, 2009, 07:25 PM
Default System Mechanic Pro
Does anybody here use System Mechanic Pro? I have used it for about two years and really like it. If not what are you using for your firewall, anti virus and utilities?
Old May 14, 2009, 03:11 AM
sswilson's Avatar
Firewall - Router
AV - AVG on the young lad's computer, none on mine
Utilities - ? What utilities do you need?
Old May 14, 2009, 05:52 AM
bojangles's Avatar
Firewall: Router and Windows Firewall
Antivirus: ESET NOD32
Utilities: CCleaner, Defraggler. You don't need many utilities to keep your computer running well.
Old May 14, 2009, 06:49 AM
gingerbee's Avatar
ccleaner avg or avastand windows firewall
Old May 14, 2009, 07:33 AM
mklym's Avatar
ESET Smart Security-firewall, av
JkDeFrag
Current Rigs
Panasonic Toughbooks
CF-18, CF-19, CF-29, CF-31, CF-52GUN
ThinkPads
X301, A31p
There is always something waiting at the end of the road, if you're not willing to see what it is, you probably shouldn't be out there in the first place.
Life's Journey is not to arrive safely at the grave in a well preserved body, but rather to skid in sideways totally worn-out shouting 'Woo Hoo! What a ride!
Old May 14, 2009, 08:00 AM
geokilla's Avatar
Firewall: Kaspersky Internet Security 8 and Linksys WRT54GSv7 with DD-WRT
Antivirus: Kaspersky Internet Security 8
Antispyware: Super AntiSpyware
Utilities: CCleaner, Driver Cleaner (rarely used), and Windows XP applications
@OP. System Mechanic Pro sounds like one of those stupid programs that claims that it can do this and do that in order to significantly speed up your computer. If I'm correct, these programs are considered to be pretty much useless by the general computer enthusiasts.
Old May 14, 2009, 10:09 PM
Wow! I should have asked what do you think of iolo firewall and antivrus. Is it any good? And if you wondering it does come with System Mechanic Pro.
Old May 14, 2009, 11:02 PM
Never heard of it.
I also see no need for a firewall as the built in firewall for windows is sufficient and if you want more buy a router.
For a antivirus I recommend AVG or Avast for free.
NOD32 or Kaspersky for paid.
Old May 14, 2009, 11:41 PM
Originally Posted by enaberif View Post
Never heard of it.
Thank you Sir.
MCP55 Pro + IO55 = 3600 pro + 3050 IO? CMetaphor CPU's and Motherboards 3 March 31, 2009 01:45 PM
[FS] FF ZA Pro loath Buy/Sell & Trade 2 November 25, 2008 09:16 AM
XP pro or home? mgp141 CPU's and Motherboards 18 January 6, 2008 08:07 AM
PC Mechanic's sneak peek at Firefox 3 Supergrover Press Releases & Tech News 0 August 24, 2007 05:10 PM
AquaXtreme MP-05 Pro Eldonko Water Cooling 6 April 18, 2007 01:53 PM
