Old May 10, 2009, 07:45 PM
vulcan500rider's Avatar
Default Need gamepad help from Linux gurus, please!
Hi guys!
I'm working on my first Linux project, an emulator box. I'm running Ubuntu 8.04, and what I'm trying to do is have each of my 4 gamepads (two NES to USB adaptors, and two 8 button gamepads) be assigned the SAME position when connected, so that gamepad 1 is ALWAYS js0, and so on. That way, once I have the buttons set in my emulator, they won't change with each reboot.
I found a good start to things on the Ubuntu forums using Udev rules, and I've found some attributes to identify each, and think I know how to create the appropriate rules to make a static SYMLINK for each device. What I don't know how to do is ask the system to put the specific SYMLINK (if its active) in the appropriate "js" position.
Here's the link to my question on the Ubuntu forum:
[ubuntu] How do I get multiple joysticks to be detected in the same order - Ubuntu Forums
If anyone has some insight into the problem, it would be very welcome!
Thanks guys!
Old May 10, 2009, 08:31 PM
Shadowmeph's Avatar
The only thing I can sugest is ask a Linux guru and at this site you probably find a couple
( this is where I go to get most of my Linux answers)
LinuxQuestions.org I am pretty confident some one there will know how to do this or at least point you in the right Dirrection
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old May 10, 2009, 09:14 PM
Thanks, Shadowmeph! I did some exploring at the link you provided, and I THINK what I need is a "link" command (ln) between the SYMLINK I set up for the particular gamepad, and the js0 directory I want it to go in. Now I just need to find the correct syntax for the command, and make sure I'm not going to screw anything up <laugh>. That said, if anyone else has any advice, I'm still all ears!
Old June 3, 2009, 07:52 AM
If you're still wondering, the syntax is:
Code:
ls -s [where you want the link to point] [where the link file should be placed]
For example, if I wanted to symlink a directory in my home folder called "music" to a folder named "media" the command would be (note that the media folder doesn't exist, ln just makes a file that points to the folder)
Code:
ln -s /home/matt/music /home/matt/media
Then both
Code:
cd /home/matt/music
and
Code:
cd /home/matt/media
would send me to the music folder. Hope that helps.
Q6600 G0 @ 3.0GHz - P5Q-E - EVGA GTX 260 Core 216 - Corsair TX750 - Coolermaster HAF 932 - Xigmatek HDT-S1283 - Mushkin Redline 2x2gb
looking for gamepad with a STIFF analog stick baov Peripherals 1 July 18, 2010 11:22 PM
Wireless Controller/gamepad. Cypher^64 Peripherals 2 February 9, 2009 06:12 PM
What Linux distro is for me? biff O/S's, Drivers & General Software 22 October 30, 2008 08:20 PM
Who is using linux? Shadowmeph O/S's, Drivers & General Software 34 February 1, 2008 03:31 PM
