Old May 6, 2009, 08:07 PM
Level up: 12% Level up: 12% Level up: 12%
Level: 14 - 512 points to level up
Default HTPC freeware suggestions
I'm in the final stages of completing my WinXP SP3-based HTPC, and I was just wondering what some various freeware programs you'd suggest I stick on it.
It's an E4600 with 3GB of DDR2 RAM, so it can take quite a fair bit of resource punishment.
MAIN RIG:
Case: Antec 900
CPU : Intel E8400 45nm Core 2 Duo @ 3GHz 1333MHz FSB
RAM : 4GB DDR2 800MHz (OCZ Platinum)
HDD : Main: 160GB (SG) Media: 500GB (WD) Storage: 1TB (WD)
GFX : HD4850 (512MB)
PSU : 610W PC Power Silencer
MoBo: Asus P5Q SE
View : Acer H213H 21.5" @ 1920 x 1080
HTPC: Under Construction
Case: Antec Minuet 350
CPU : Intel E4600 65nm Core 2 Duo @ 2.4Ghz 800MHz FSB
RAM : 3GB DDR2 667MHz
HDD : WD 80GB IDE
GFX : Sapphire HD4550 LP
PSU : 350W Antec
MoBo: ASUS P5KPL-AM SE
Old May 6, 2009, 08:32 PM
jdrom17's Avatar
Level up: 47% Level up: 47% Level up: 47%
Level: 24 - 888 points to level up
Definitely MediaPortal with the StreamedMP skin.
Dending how you get your movies onto the HTPC, Moving Pictures is great if the movies are ripped to the HDD/Network drive. Gives you some nice cover/fan art and movie description.
And if you download TV shows, grab TVSeries. Works similar to Moving Pictures but is for TV shows.
Old May 7, 2009, 05:47 AM
Thanks, i'm definitely going to give that mediaportal a spin :P
I think i'll wait until i have my tv tuner installed before i install the program though; that way my hardware's all up and running before it starts up.
MAIN RIG:
Case: Antec 900
MoBo: Asus P5Q SE
HDD : WD 80GB IDE
PSU : 350W Antec
Old May 7, 2009, 09:30 AM
jdrom17's Avatar
I hear the TV support is a bit lacking though so you might want to hit up the forums to make sure your hardware is compatible.
Old May 7, 2009, 09:38 AM
vulcan500rider's Avatar
Level up: 67% Level up: 67% Level up: 67%
Level: 12 - 134 points to level up
Ooo! I love that skin, jdrom17! It's been a while since I used Mediaportal, but I'm almost tempted to start playing with it again!
Old May 7, 2009, 09:42 AM
Level up: 62% Level up: 62% Level up: 62%
Level: 27 - 874 points to level up
http://xbmc.org/
:D
CSE: Corsair Obsidian 800D
MOB: DFI Lanparty JR
CPU: Intel C2Q 9550 @ 3.0ghz
RAM: 4gb G.Skill Pi PC2-8800
GPU: XFX 8800 GT Alpha Dog Edition
PSU: PC P&P 750w (Original)
Heatware: My Heatware
Old May 7, 2009, 09:59 AM
"Quote This..."
Level up: 71% Level up: 71% Level up: 71%
Level: 21 - 358 points to level up
I use Zoomplayer to play all my movies, Home Max edition is free. Does HD stuff better than anything else.
Inmatrix.com - Zoom Player Download
EVGA X-58, 6gb DDR31600mhz, i7 920 @ 4200, SLI GTX 260's at 720/1280, Passive watercooling. 3 - 60gb Vertex SD's in Raid 0.
Old May 7, 2009, 11:54 AM
Level up: 38% Level up: 38% Level up: 38%
Level: 25 - 1,145 points to level up
+1 for Zoomplayer, Small and will play anything I throw at iit.
Shareware/Freeware gems Shadowed O/S's, Drivers & General Software 61 November 24, 2009 02:44 PM
Suggestions please :) iLuvnoobs New Builds 11 February 17, 2009 04:31 PM
Suggestions Please? arekieh Troubleshooting 9 December 4, 2008 05:29 PM
Need some suggestions lpfan4ever Power Supplies 6 December 3, 2008 04:36 PM
Suggestions Corpus Masochist Overclocking, Tweaking and Benchmarking 18 April 26, 2007 04:31 PM
