<~----> GRUB error 22 - Hardware Canucks
Old May 1, 2009, 10:55 AM
Default GRUB error 22
Hi, yesterday I repartioned a part of my Vista partition so I had a partition for music and documents and the other for vista. I have another partition for Ubuntu 8.10. I am not great with linux but I usually manage, but this one has stumped me. I booted my computer today and I got a Loading Grub 1.5 Error 22 and that is it. I tried the Windows DVD and tried the fix boot option and restore, nothing. I tried the Ubuntu CD and there is no repair option for it just the Live environment.
So now I am stuck. What do I do? Do I have to get rid of Ubuntu, fix GRUB, reinstall everything? Or is there a simple fix to this? I read a ton of stuff on fixing this error but all the solutions are for XP, none so far for Vista. Please help ASAP as I want to be able to get into Vista again, I dont care if I have to get rid of Ubuntu, I dont really use it anyway.
http://www.engagepc.com
My blog, all about computers, games and technology
Old May 1, 2009, 11:01 AM
CMetaphor's Avatar
Quadfather
A fixboot and fixmbr didn't solve the problem? If you do both of those from the Windows Recovery console you should be able to boot into Windows without issues, since those two commands will rewrite the the boot sector to recognize the Windows partition.
Old May 1, 2009, 11:36 AM
I was under the impression that those were for XP? And if they are for vista, how do I do fixboot and fixmbr?
Old May 1, 2009, 11:37 AM
CMetaphor's Avatar
Quadfather
Give me a few minutes to "Brush up" on my Vista, haven't used it in a while lol...
Old May 1, 2009, 11:41 AM
ok, thanks for your help. I'll be waiting.
Old May 1, 2009, 11:42 AM
CMetaphor's Avatar
Quadfather
Found it: (Startup Repair)
How to automatically repair Windows Vista using Startup Repair
Old May 1, 2009, 11:49 AM
ok, thanks, reading it now and I'll try what it suggests. I'll post back with the results.
Old May 1, 2009, 11:51 AM
ah, after reading it I already did the start up repair. It said everything was fine and vista would start normally. Of course it wont. Any other ideas?
Old May 1, 2009, 11:52 AM
Grub Error 22 is a deleted partition.
If your running Linux and Vista then your going to have to read the manual on reconfiguring grub to recognize all your partitions.
Old May 1, 2009, 11:56 AM
what manual?
Mystery error . . . NyteOwl Troubleshooting 4 September 6, 2008 06:59 PM
Opera error Kilauea Suggestions & Feedback 6 September 5, 2008 05:59 PM
fatal error help maurier CPU's and Motherboards 1 June 13, 2008 07:10 PM
dc purchase error jay51 Suggestions & Feedback 8 April 29, 2008 02:51 PM
Vista error biff Troubleshooting 3 March 2, 2008 06:46 AM
